07-08-2012, 12:12 AM | #1 |
window felts
What did you use to stick your new window felts around the door window openings? Has anyone used anything other than the screws/staples that come with the kits.
thanks GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
07-08-2012, 12:16 AM | #2 |
Re: window felts
I did not use the staples that came with it. They seemed impossible to use as instructed. I used 3M Super Weatherstrip and Gasket Adhesive and worked great. http://macsautoparts.com/early-v8-fo...0R3CHL1076927/
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
07-08-2012, 06:36 AM | #3 |
Re: window felts
I drilled small one eighty holes then yoused rivets worked great Rog.
07-08-2012, 06:51 AM | #4 |
Re: window felts
Macs sells the small screws, I drilled 3/32 holes and the screw heads aren't visible or anywhere near the glass surface once installed.
http://macsautoparts.com/early-v8-fo...0R3CHL1077114/ |
07-08-2012, 08:40 AM | #5 |
Re: window felts
Does anyone know, if there is any other manufactures of window felt kits for a 39 Ford other than Vintique? Thank You Marv
07-08-2012, 09:44 AM | #6 |
Re: window felts
07-08-2012, 06:37 PM | #7 |
MEMBER EMERITUS
Re: window felts
bob Drake makes them - or used to
07-08-2012, 08:10 PM | #8 |
Re: window felts
Be more careful than I was if you use screws. I left one to high and cost me another side window due to a Big crack.
~~Walts37~~ |
07-08-2012, 09:34 PM | #9 |
Re: window felts
Another reason I stick with the 3M adhesive.
07-08-2012, 11:56 PM | #10 |
Re: window felts
Thanks for your input fellas. Mine is Vintique ex C&G Ford. Twenty years ago for my last car they came from Dennis Carpenter , I think. Same screws but no staples.
GB
07-09-2012, 07:10 AM | #11 |
Re: window felts
I bought the clips that are supposed to be like the original installation. I have not installed the fuzzies yet. Has anyone use the clips?
07-09-2012, 07:18 AM | #12 |
Re: window felts
I use the clips. I modified a standard vice grip plier to close against a stop in order to clamp all the clips the same amount onto the fuzzy. Any pliers will work because it doesn't take much pressure to clamp the clips tight. Cut off a short length of fuzzy to experiment with exact placement of the clips so it looks right once installed. john
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. Last edited by john worden; 07-09-2012 at 07:26 AM. |
07-10-2012, 07:50 AM | #13 |
Re: window felts
1/8" aluminium pop rivets low down on the felt and paint the heads black (or dog sh*t)
07-10-2012, 07:54 AM | #14 |
Re: window felts
I've used safety wire with the safety wire tool.
