#1 |
59A Flathead Engine Standard Bore.
So just pulled off intake manifold to replace sheared generator securing stud. 9/16 UNC. Noted in the valve gallery some oil present? Correct me please if my thoughts or assumptions are wrong. There should not normally be oil present here or not. Oil if here will drain back to oil pan via? This engine has good compressions and good oil presssure. Nil oiling of plugs. However it uses some oil and noted at acceleration. Reported engine has few miles on rebuild. Could this oil in this space be taken into combustion space and burnt via inlet valve guides. The presence of oil in this valve area has me thinking.This area is where the oil is being used as opposed to getting past rings and burning? Thanks for assistance Phil NZ. |
#2 |
There should be plenty of oil or at least signs of oil in that area. It drains back to the crankcase through the holes covered by those shields that clip onto the oil feed tube.
I put a couple of magnets in the little recesses in the middle of that area. Mart. |
#3 | |
![]() Quote:
Much appreciated for your clarification. Under the shields for the drains no wonder I did not spot them! Will check again in this area. Phil NZ |
#4 |
Interesting idea with the magnet, Mart.
#5 |
I know what I'm doing next time my intake is off!
I love breaking open obsolete computer hard drives and getting the magnets out of 'em! Strong as wolverine piss! They will not wander. Now back to the original poster's question. Here's what you DON'T want to find. This was in the '37 block pulled from one of my cars last winter.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 06-11-2019 at 05:36 PM. Reason: Added pic, and turn back on topic. |
#6 |
#7 | |
![]() Quote:
Sorry back to the original topic! <smacks fingers>
#8 | |
![]() Quote:
But will remove inlet manifold again, Remove attached covers on oil line and visually check drain holes are all clear. Then continue with the long term plan of an engine swap and attend to hone, rings and valve guides for oil consumption. Phil NZ |
#9 |
When I was in High School, our Auto Shop teacher told us that is what you get when you use Pennzoil. Gary Troxel ndobedo@aol.com
#10 | |
![]() Quote:
#11 |
So today removed inlet manifold to access valve valley area again.Removed covers on oil feed line. All drain holes are clear. Thanks to Mart for info supplied. Will either be nil seals at inlet valves or glazed bore for the cause of my oil usage. This will happen some time!
Phil NZ |
Thread Tools | |
Display Modes | |
