Old 04-23-2019, 06:55 PM   #1
gtdohn
Default 1950 vs. 1941 Pickups
I have a question for those of you that have experienced both vehicles. Does the 1950 Ford F1 pickup handle and drive any different (or better) than a 1941 1/2 ton pickup? And if so, in what way and why (better components, etc.)
Thanks
gtdohn is offline   Reply With Quote
Old 04-23-2019, 07:30 PM   #2
Anteek29
Anteek29's Avatar
Default Re: 1950 vs. 1941 Pickups
I'd like to know too...I was pleasantly surprised that my '41 handles and drives like a regular car
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 04-23-2019, 07:39 PM   #3
gtdohn
That is interesting to hear that your '41 drives so well. What wheel and tire combo are you running? I just installed new king pins and new tie rods with sleeve, along with a new drag link and I'm not at all happy with the way it drives. I am thinking it is the 6.00 x 16 bias ply tires.
Old 04-23-2019, 07:53 PM   #4
Lanny
Lanny's Avatar
The toe-in is pretty critical for good steering, I believe it should be 1/8" toe-in.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 04-23-2019, 07:55 PM   #5
alanwoodieman
put some radials on it! toe-in 1/16 to 1/8"
alanwoodieman is offline   Reply With Quote
Old 04-23-2019, 08:01 PM   #6
gtdohn
That's what I would like to do, but I will need a new set of rims that will take radial tires. I don't want to have to run tubes anymore.
What would you suggest for rims?
Old 04-23-2019, 08:31 PM   #7
RalphM
RalphM's Avatar
That’s because 1941 pretty much had a car frame underneath it. It was in 1942 when they went to the ladder style frame for the half ton trucks.
So I would think that would have a lot to do with the ride.
RalphM is offline   Reply With Quote
Old 04-23-2019, 08:40 PM   #8
skidmarks
skidmarks's Avatar
41 is easier to make it ride better then a 50.
If you dont use it as a truck you can put lighter springs in it .
Rims for radial 15" tires you can get from a 70s to 80s ford pickup
I got radial tubeless tires on 56 to 66 rims so I can use the stock hubcaps
skidmarks is offline   Reply With Quote
Old 04-23-2019, 09:25 PM   #9
gtdohn
DO you know of any for sale?
Old 04-23-2019, 10:35 PM   #10
Lanny
Lanny's Avatar
You should figure out what size tire you would like to run and then find wheels
that will work for the tire size you want.
Do you want to run a narrow tire, like was on it originally, or would you like to
run a wider tire, if so, how wide ?
Also 1966 was the last of the Ford pickup wheels to have the "innie" hubcap mount
tabs and '40 to '66 pickup hubcaps fit these wheels. !967 thru 1996 Ford 1/2 ton
pickup wheels have the "outie" hubcap mounting tabs for a 10 1/4" hubcaps.
1967 thru 1996 Ford 1/2 ton pickups commonly have 15" wheels, and generally
speaking, the wheels from the late 60's to early 70's commonly have 5" and 5 1/2"
wide wheels, and generally the newer you go, the wheels get wider. So 80's and 90's
wheels will usually have 6" to 6 1/2" wide wheels on Ford 1/2 tons.
Old 04-23-2019, 11:08 PM   #11
gtdohn
I believe the early '66 rims were about 5" wide and that would be fine. I definitely want to use my original center caps. So whatever tire would fit on a 5" rim would be great.
Old 04-24-2019, 01:46 AM   #12
flatheadmurre
flatheadmurre's Avatar
You want wide and original hubcaps...maybe the lincoln rims will do that..others will chime in that knw it betrer...
The later ones doesnt accept early hubcaps.
Old 04-24-2019, 05:51 AM   #13
Charlie ny
Or try Summit........I went to 15's on my '41, 6" rear 5" front . These wheels had the correct grabbers for the '41 hub caps. Delivery the next day.
Between the two I favor my present '41 over the '51 I had for many years.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 04-24-2019, 06:06 AM   #14
skidmarks
skidmarks's Avatar
The 50s lincoln 15" rims dont have the indie hub cap nubs
Old 04-24-2019, 07:42 AM   #15
FortyNiner
FortyNiner's Avatar
So, was the front end aligned after the tie rod work?
What is it about the way it drives that you don't like? I'm not clear which vehicle is the issue.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 04-24-2019, 07:47 AM   #16
Ol' Ron
Ol' Ron's Avatar
I'd shy away from 15" wheels as tires for that size is being limited as no car manufacture us using that size anymore. Dodge rucks use 5 on 5 1/2 bolt pattern in 16". I converted my truck to 5 on 4 1/2. Much better selection of wheels.
Old 04-24-2019, 08:27 AM   #17
tubman
tubman's Avatar
I hate to be contrary, but if you don't mind radials, there are a lot of 15" tires available. A lot of little foreign cars use them as standard equipment. I just bought a set of tires for the little ladies Kia. There seemed to be a wide selection out there.
Old 04-24-2019, 08:37 AM   #18
RKS.PA
RKS.PA's Avatar
gtdohn, are you sure you can't put radials on your current rims without tubes? I think there have been quite a few discussions here where that's been done successfully with car rims, but I'm not sure if your '41 truck rims may be different?
RKS.PA is offline   Reply With Quote
Old 04-24-2019, 09:40 AM   #19
D. Jones
D. Jones's Avatar
I run radials, 225 x 70 x R 16, on my 45 pickup on the original 16" x 4" rims with no tubes. So far, 3 years and 15,000 miles, no problem. Would rather have 5" wide rims but haven't been able to come up with a good set.
D. Jones is offline   Reply With Quote
Old 04-24-2019, 09:41 AM   #20
cas3
if the area around the valve stem hole on your 16" rims is in good shape, not rusty so it will take a tubeless valve stem without leaking, and the bead area good, thats what i would do, go 16" tubeless. i know this argument has been fought for decades, that tubeless rims are special bla bla, but i dont buy it. you do need good wheels though or you will get slow leakers
