Old 07-08-2017, 04:22 PM   #1
31 RPU
Default Victoria Steering Column
Is there any difference in the steering columns on a regular model A Ford and a Victoria? I know the Victoria is dropped about 1 3/8" at the steering column bracket on the gas tank , but is there any difference between the Victoria steering column and any other model a Ford steering column?
31 RPU is offline   Reply With Quote
Old 07-08-2017, 04:43 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Victoria Steering Column
Yes and no. There is a difference between a column that would be used in a Vicky vs a 7-tooth column, but during the production time of all Victoria's, they shared the same steering column & gearbox with the other cars being produced on the Ford assy line.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-08-2017, 05:19 PM   #3
31 RPU
It is a two tooth. Thanks.
Old 07-09-2017, 10:58 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
The 190A uses a 2-tooth Gemmer steering which is common to other 1930-'31 Model A's. Avoid the Ford 2-tooth steering because it has bastard angle ball bearings and a bastard worm gear to match.
Bob Bidonde
