Old 09-28-2010, 08:57 PM   #1
deuce295
deuce295's Avatar
Default 6 Volt Relays
Need a little help finding a source for some 6 volt automotive type relays. Something similar to the bosch type relays. If anyone has purchased any lately I would really appreciate info on where you got them. Thank You. Appreciate any leads.
deuce295 is offline   Reply With Quote
Old 09-28-2010, 10:16 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 6 Volt Relays
Any junk yard with old 6 volt cars will have horn relays. Not sure what you mean by "BOSCH" type relays, but many surplus stores have an assortment of relays. The "AXMAN" and "ABC ELECTRONICS" in Mpls. have many relays.
Old 09-28-2010, 11:08 PM   #3
JoeWay
JoeWay's Avatar
Here's an example--just a standard aftermarket NO/NC relay, often offered with a socket with five wires.
Bosch Relay
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 09-28-2010, 11:11 PM   #4
J Franklin
J Franklin's Avatar
Try a NAPA store
Old 09-29-2010, 01:48 AM   #5
Tom Wesenberg
Bosch Relay
Joe
That's the type of relay I figured he meant. I was surprized to see Tyco bought the Bosch auto relay business.
A similar relay should be found at the electronics stores. Just make sure the contacts are rated for at least the amps being used.
Old 09-29-2010, 03:01 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
How about these?
6v horn relay
6v head light relay
