11-27-2016, 09:44 AM | #1 |
1933-34 Original Brass/Copper Ford Radiator
City:
South Jersey
State:
NJ
Price:
475.00
Original 1933-34 Ford V8 brass radiator In good condition. This radiator was checked for leaks . The seam or the tank was repaired. A small pinhole was found in the middle of the back. This was not repaired due to the damage it causes to the thin cooling fins when torch heat is applied. Best recommendation for this is to use a tube of Aluma Seal, which I will provide. There is an old repair at the bottom left of the inside As you can see the repair left some cooling fins damaged. This is heavy and weighs about 50 lbs. UPS shipping has been chosen. The buyer should wait before paying until an exact shipping quote is provided. This is a good radiator and better than the ones I've seen previously listed for sale. $475 plus shipping (UPS or FedEx)
12-06-2016, 11:34 PM | #2 |
Re: 1933-34 Original Brass/Copper Ford Radiator
Bttt
12-09-2016, 06:01 PM | #3 |
bttt
12-26-2016, 01:21 PM | #4 |
bttt
01-09-2017, 04:33 PM | #5 |
