Old 01-06-2021, 06:49 PM   #1
Conaway2
Conaway2's Avatar
Default Roadster Door Hinge Screws
I need several of the screws that hold the door hinge to the car body. The screws I’ve bought from vendors don’t fit. Does anyone know what size these screws are ? There are three screws on each hinge.
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 01-06-2021, 09:54 PM   #2
SteveB31
SteveB31's Avatar
Default Re: Roadster Door Hinge Screws
Need to know what year roadster,
1928-1929 roadsters use 1-4-28 for door hinge to cowl
1930-1931 roadsters use 5/16-24 for door hinge to cowl
Steve
SteveB31 is offline   Reply With Quote
Old 01-07-2021, 09:47 AM   #3
Conaway2
Conaway2's Avatar
Steve - thanks - the car is a ‘31 roadster.
Jim
Old 01-07-2021, 10:06 AM   #4
Planojc
Planojc's Avatar
got mine from Brattons and they fit fine.
Planojc is offline   Reply With Quote
Old 01-07-2021, 03:22 PM   #5
redmodelt
redmodelt's Avatar
If you got the screws from a reputable supplier and for the correct year, make sure the holes were not re-tapped for different thread or cross threaded. If you have the old ones that came out, check the thread count.
Old 01-07-2021, 03:35 PM   #6
Conaway2
Conaway2's Avatar
I just ordered another set of screws. One screw is missing on the lower hinge, and I can’t get the others out. Unfortunately, the lower hinge is loose, so I hope I can tighten it up with a new screw.
Old 01-07-2021, 06:36 PM   #7
fundytides
fundytides's Avatar
Just did the hinges on my 31 Roadster a short time ago. Used some original screws and some new ones from Bratton's and they worked fine. Make sure you use the cup washers and internal lock washers as well.
fundytides is offline   Reply With Quote
