Old 12-22-2017, 11:00 AM   #21
Licensed to kill
Licensed to kill's Avatar
Default Re: Tire pressure for tires on a model A Ford
I'm in awe that a couple PSI of air pressure in your tires concerns you but $8 a gallon for gas does not.
Licensed to kill is offline   Reply With Quote
Old 12-22-2017, 03:23 PM   #22
Purdy Swoft
Purdy Swoft's Avatar
He probably doesn't have a choice when it comes to the price of fuel .
Old 12-23-2017, 07:29 AM   #23
KGBnut
KGBnut's Avatar
I think that you are trying to be a little too picky. 2.5 bar is a hair over 36 lbs. You will never notice a difference that small. Most off-the-shelf gauges are only accurate to 1-2 lbs.
You are not running a high precision race car. For your purposes, 2.5 bar falls well within what I call "acceptable degrees of good-enoughness."
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 12-23-2017, 10:05 AM   #24
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Isn't it AMAZING, that someone hasn't come up with something BETTER than the conventional PNEUMATIC TIRE????
Years back, a Frenchman tried a HUGE coil spring, inside the tire, even!
Either Pirelli or Michelin??? made a tire with changeable tread section, PRETTY TRICK!! My Friend, Mike Scelzi, had a set on his Old Volvo, 544-Sport. He grabbed them from a Trade In Car!!!---It's good to ALWAYS be BUDDIES, with the Used Car Manager---LODeals!!
Train WHEELS/TRACKS are even the same OLD Design. Train Track width, mimicked the spacing of CHARIOT Wheel tracks & still DOES!!!
Bill History101
"THE ASSISTANT GURU OF STUFF"
Old 12-23-2017, 11:59 AM   #25
Licensed to kill
Someone did. https://www.youtube.com/watch?v=LN8VwD0V4RE
Old 12-23-2017, 03:09 PM   #26
BILL WILLIAMSON
Looks like those GOLD, HONEYCOMB wheels, on some Pontiacs. Better than all the SPOKEY Mags, we see EVERYWHERE! Looks like WAGON WHEELS--LOL
Bill Wheeler
Old 12-23-2017, 04:01 PM   #27
Tom Wesenberg
Tom Wesenberg's Avatar
Real men don't use a gauge...........they just kick the tires. If the big toe hurts, then they have enough air.
Old 12-23-2017, 04:14 PM   #28
JJASON
JJASON's Avatar
safety beads were put on rims for a reason.
JJASON is offline   Reply With Quote
Old 12-23-2017, 08:11 PM   #29
Dino's A
Dino's A's Avatar
I'm with Purdy-35 psi.
Dino's A is offline   Reply With Quote
Old 12-23-2017, 11:02 PM   #30
BILL WILLIAMSON
Truckers check their air by BANGING on the tread, with a BIG Iron Bar. NO, they're NOT MAD at the TRUCK---LOL
Bill Thump
Old 04-23-2018, 11:00 AM   #31
Joop
Joop's Avatar
Here in AZ when you fill it to 35 PSI and after a 2 hour drive in warm weather 85+ degrees
the pressure of the tire had increased to 40 PSI, car was bouncing so I lowered it to 30 PSI for a nicer ride..
Joop is offline   Reply With Quote
Old 04-23-2018, 02:18 PM   #32
Jw
1 bar = 14.50 psi, not that difficult
Jw is offline   Reply With Quote
Old 04-23-2018, 02:54 PM   #33
slammin
slammin's Avatar
Originally Posted by eagle View Post
Mine say max PSI 45 lbs, that's right where I keep them.
Max pressure on the tire sidewall is the max pressure the tire manufacturer recommends. The correct tire pressure for modern cars is displayed on the drivers door. The accepted correct tire pressure for the model A (according to Henry) is 35 pounds. That's good enough for me.
slammin is offline   Reply With Quote
