05-17-2017, 07:11 PM | #1 |
41 Ford Heater Query
i want to hook up the heater in my 41. At present, the heater pipes protrude from the firewall without hoses.
Where does the heater core draw water from the engine? I thought it was from around the water pumps, but can't see where this might be. All assistance greatly appreciated. |
05-17-2017, 07:23 PM | #2 |
Re: 41 Ford Heater Query
Most likely like 39 & 40. Punch a hole lower pass radiator hose. Install heater hose fitting (sold at most classic ford vendors) upper heater hose goes into top of pass head.
Thanks - 30-9 1939, 1940 |
05-17-2017, 08:44 PM | #3 |
I have attached the installation instructions for the earlier model but it shows the correct location for the engine connections on page 6. Hope this helps? Cheers, meric42
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
05-17-2017, 08:50 PM | #4 |
Do you know if the heater core is still good? Most were disconnected because of a leaky core, which can really make a mess.
05-17-2017, 09:37 PM | #5 |
Here's the 1945 Version as well
05-18-2017, 03:35 AM | #6 |
Below is the connection needed for that lower radiator hose. -tony.
tony-starr.com Last edited by tony starr; 05-22-2017 at 04:56 PM. Reason: image went missing |
05-20-2017, 09:00 PM | #7 |
05-20-2017, 09:01 PM | #8 |
05-20-2017, 09:02 PM | #9 | |
05-20-2017, 09:24 PM | #10 |
Upper and lower fittings.
05-21-2017, 08:16 PM | #11 |
The pic of the valve which screws into the passenger side head is not correct but is what is sold I had to modify it to be correct see pic
The valve in the center is the one I made by cutting off the ends of the new valve The valve in the center is the final product |
05-21-2017, 08:22 PM | #12 |
One more thing as for tapping into the lower radiator hose I took a 3 inch piece of tubing welded a small nipple threaded so I could also install a valve on both sides of the heater core
