Old 05-24-2015, 07:15 PM   #1
Vin-tin
Vin-tin's Avatar
Default service brake shaft bushing area rebuild
What works best to rebuild the bearings and shaft?
I know what's available from the venders, I just need to know what usually works the best.
Should I use brass or nylon bushings?
Split or solid?
As far as the shaft goes, is it best to build up the shaft or simply press on a sleeve?
I don't know if the shaft or bushing (or both) is worn until I remove the old bushing.
And i really didn't want to remove the arms, but I will if I have to.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 05-24-2015, 07:31 PM   #2
aermotor
Default Re: service brake shaft bushing area rebuild
You have nothing to lose by cutting off the old bushing to see what you have and what direction to go. It may be bushing wear and you won't have to remove the arms and replace with split bushings.
John
aermotor is offline   Reply With Quote
Old 05-24-2015, 07:37 PM   #3
Vin-tin
Vin-tin's Avatar
What's the best way to remove the old bushing without damaging anything else?
1929 Coupe
1930 Coupe
Old 05-24-2015, 10:21 PM   #4
RonC
RonC's Avatar
Cut the bushing with a hack saw and replace with split bushing is the easiest. The best way is to remove the arms and rebuild the worn shaft or install brattons sleeve.
RonC is offline   Reply With Quote
Old 05-24-2015, 10:58 PM   #5
31 Vicky
I have used a cut off wheel on my Dremel, careful not to nick the shaft.
A's Always
Dave
31 Vicky is offline   Reply With Quote
Old 05-25-2015, 05:23 AM   #6
Norm M
My cross shaft bushings were bad - one was very sloppy and the other was binding. I followed the instructions from Les Andrews' book page 1-77 and pressed the shaft out (using a 20 ton press) after cutting the cushings and drilling the pins. Using the rebuild kit from Bratton's, I repaired the area of the shaft for the bushing with the sleeves provided, put on the new brass bushings and pinned the levers back on. Installed in the car and the cross shaft operates smoothly. It is not difficult if you have access to a press and I think it will give you results which are like the originally installed.
ps: This is my first attempt at restoring an "A"
Norm
Norm M is offline   Reply With Quote
