04-30-2020, 12:55 PM | #1 |
Upper Distributor Plate
A friend was looking at a number of upper distributor plates he had collected over the years and noticed that some have a letter and number stamped into them like K1 for example. Is this a date code like the starter bands have? If so what is the code?
Thanks in advance - Hunter |
04-30-2020, 01:11 PM | #2 |
Re: Upper Distributor Plate
Could very well be a date code. The coil on my car has a code of 3K which is March 1930. If it is a code it would be Jan. 1930.
04-30-2020, 07:06 PM | #3 |
Never seen a code on a plate before. I will have to check when I get a large group of NOS ones in the next few days.
"The more things change, the more they stay the same." |
05-01-2020, 06:43 AM | #4 |
Of the numerous upper plates I have recently cleaned, I only noticed that the 3 Autolite marked ones had a code (1K, 4K and 2L), I didn't see any code on the unmarked or SP plates. The plate that came out of the distributor which was original to the car had the 1K (Jan 1930?). I believe this would be correct for that car since it is an early Feb 1930 car.
This drives the next question - were the distributors sent by the manufacturers to Ford as a completed assembly? |
05-01-2020, 07:55 AM | #5 |
