09-23-2017, 01:48 PM | #21 |
Re: Temp gauge installation
I don't think it gets better than this, Vintage Precision housing with Thermostat in stalled, probe for temp gauge running through junction box, Clean, and neat!
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
09-23-2017, 02:30 PM | #22 |
I have the same set-up that Mark has. The VP T-stat housing has 2 outlets on it. I use one for the temp gauge and the other for my heater water.
09-23-2017, 02:30 PM | #23 |
The attached article is how I installed a temp gauge in my Victoria.
Tom Endy |
09-23-2017, 05:42 PM | #24 | |
Thank You;
Brian French; 1930 Briggs Town Sedan |
10-08-2017, 07:12 AM | #25 |
How much temp drop should a good radiator measure? I suspect the one i am working on is shot. It drops only about ten degrees when measured with an hand held IR measuring tool.. I am thinking 20 degrees might be a target?
Live in the Past.... It's cheaper. |
10-08-2017, 07:21 AM | #26 |
10-08-2017, 07:27 AM | #27 |
My original 1928 radiator drops the temp about 20 degrees. I back flushed my cooling system by using a sump pump, after I used vinegar for a month. Vinegar made a mess, and next time I'll use RUST911.
10-08-2017, 07:43 AM | #28 |
Chief always chose the L/R side of the cylinder head. Study a head & you'll find a good spot to drill & tap. That was a common spot on MANY Flathead Engines.
Bill W.
10-08-2017, 08:40 AM | #29 | |
10-08-2017, 08:42 AM | #30 |
that is not factory
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
10-08-2017, 09:15 AM | #31 |
My A had the breather vent tube routed along and inside of the left frame rail under the drivers seat instead of below the car to take advantage of the draft. I still wonder about that.
10-08-2017, 11:21 AM | #32 | ||
Also helps keep the left side of your engine compartment clean. Last edited by Y-Blockhead; 10-08-2017 at 11:35 AM. |
10-08-2017, 05:16 PM | #33 |
I have a temp gauge on all 3 of my Model As. I put the threaded fitting in the outlet myself because I don't like the idea of having it come out the side like the ones the vendors flog. Once the sensor is installed, it makes getting to the head nut directly under it, difficult. Mine come out of the back of the outlet.
