Old 05-02-2017, 07:50 PM   #1
Terry, NJ
Terry, NJ's Avatar
Default Anyone have any experience with Speedometers?
The next problem with the coupe, The speedometer! It was working, then one day after a fast run, I noticed it was still. No speed or mileage.Tonight I crept underneath and took the drive gear off. It is the keyed shaft type. I fitted the cable drive and spun it and it was free. All was OK down below. Topside, I have checked the square drive in the back of the gauge. Everything seems OK. Does this sound like a busted meter? I have a spare, but the numbers need replacing so I haven't swapped them yet. Plus I've been fiddlin' with the running gear and the engine so I haven't devoted much time or effort to the speedometer. I've oiled the bearings that I can get at without disassembly.
Terry
Terry, NJ is offline   Reply With Quote
Old 05-02-2017, 08:29 PM   #2
jdupay
jdupay's Avatar
Default Re: Anyone have any experience with Speedometers?
Sounds like something inside is busted. My first thought was a stripped square drive, but you checked that. I just sent my speedo to Mark Nelson. I don't know yet if he will do a good job, but here is a link to his website:
https://www.marksspeedometer.com/
Joe
Minneapolis, MN
1929 Std Coupe
jdupay is offline   Reply With Quote
Old 05-02-2017, 09:44 PM   #3
1955cj5
1955cj5's Avatar
papanick repaired mine...it works great and a quick turnaround...
https://www.fordbarn.com/forum/showthread.php?t=216905
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-02-2017, 10:40 PM   #4
Larry Jenkins
Papanick. He cares..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 05-03-2017, 01:17 AM   #5
CarlG
CarlG's Avatar
I am another satisfied customer of PapaNick
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-03-2017, 07:52 AM   #6
SeaSlugs
SeaSlugs's Avatar
same with Papa, there are 2 different sized square drives in the speedometer BTW, the cable could have twisted apart in the housing too. I have seen a fair share of stripped speedometer drive gears off the driveshaft as well...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-03-2017, 08:18 AM   #7
Jim M
Jim M's Avatar
X5 with papanick. Fast and did beautiful job. Very satisfied!
Jim M is offline   Reply With Quote
Old 05-03-2017, 08:33 AM   #8
dandbbakker
mark will do a good job no worries there
dandbbakker is offline   Reply With Quote
Old 05-03-2017, 08:56 AM   #9
jdupay
jdupay's Avatar
That's good to hear. I was getting worried I picked the wrong guy. I will post back here with the results just to close the loop.
Joe
Minneapolis, MN
1929 Std Coupe
Old 05-03-2017, 09:28 AM   #10
Bruce Lancaster
A minor extra test before you act: One of the little square bits that come in sets approximates speedo drive well enough to work. Give your speedometer a spin with such a bit and an electric screwdriver or drill. That will definitively pin down the problem as speedo or something in drive. And you can very roughly gauge what speedometer reads if you know RPM of the tool, comparing that to the 1000 RPM=60 MPH of the gauge.
Bruce Lancaster is offline   Reply With Quote
Old 05-03-2017, 09:36 AM   #11
jdupay
jdupay's Avatar
Now that is a great idea!
Joe
Minneapolis, MN
1929 Std Coupe
Old 05-03-2017, 10:00 AM   #12
Bruce Lancaster
Forgot to say...be sure it's turning the right way! One way is going to read zero for sure...
Old 05-03-2017, 10:11 AM   #13
KGBnut
KGBnut's Avatar
The way I read your original post it is clear that you ensured the speedometer cable is not binding, but did you check to see if it is broken?
Forgive me if I read your post wrong.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 05-03-2017, 11:37 AM   #14
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
First make sure your main shaft is not binding. A common problem. You should be able to turn the speedo shaft with your fingers.
Jacksonlll is offline   Reply With Quote
Old 05-03-2017, 12:48 PM   #15
Mark in MT
Make sure that the square drive end on the cable is the correct one for your speedometer, ovals used .124 square, round faced units used .104 square. I am posting a copy of my speedometer notes that I send out to my customers with some info regarding the care and feeding of these instruments.
Mark’s Model A Service, Llc
33691 Finley Point Rd.
Polson, MT 59860
Marksspeedometer.com
Notes on your rebuilt speedometer
This instrument has been completely rebuilt. It has been disassembled, cleaned, inspected, lubricated, carefully reassembled, and calibrated.Every care has been taken to create a speedometer that looks and performs as well as when it was new.There are some things to keep in mind.
1) Make sure that the end of your speedometer cable is in good condition.If it is rounded on the corners where it goes into the speedometer head, it may slip instead of turning the speedometer.
2) If the instrument is an Oval (28-mid 30), make sure that the end of the cable is .120-.124 square. Make sure that the cable will insert into the speedometer head far enough.The depth of the hole is about 7/16”, but the first 1/8” is round, then it transitions to a square hole.The end of the cable must extend far enough into the head so that it goes at least 3/8” into the input end. The later round units and most other cables are .104 square.They will work for a little while, but will start slipping and round out the drive in the bottom of the speedometer.
3) Now is a good time to inspect and relube the speedometer cable, looking for kinks and places where it is starting to fray. These will catch on the inside of the housing and make the speedometer reading erratic.
4) Make sure that the cable starts squarely into the bottom of the unit; they are easily cross-threaded.
5) There are other factors that affect accuracy other than the speedometer unit. Tire size, rear axle ratio, and drive gear tooth count at the torque tube all make a difference on how the unit will read.I calibrate the units to the standard, which is 1000 revs/mile.If your speedometer is not reading correctly, check the odometer against the mile posts along the highway for several miles, if the odometer is not reading the same as the mileage posts then the cable is not turning 1000 rev/mile.(Most likely the speedometer error will be the same percentage amount in the same direction.)
Any question, contact me @ 406-249-3104
Thanks,
Mark Nelson
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 05-03-2017, 01:30 PM   #16
1955cj5
1955cj5's Avatar
Just for the record, I sent mine to papanick because I happened to see his ad in the Swap section...
I could just have easily sent it to Mark in Montana as he is much closer....I just didn't see his Swap post first!
Old 05-03-2017, 02:13 PM   #17
papanick
Hay you can send it to any of us and we will do a good job. One rebuild dose not try to out build a other. But if you do not get it working I will be very happy to make any repairs that are needed. [email protected] I have been doing them for over 20 years.
papanick is offline   Reply With Quote
Old 05-23-2017, 01:25 PM   #18
green30coupe
green30coupe's Avatar
I'm a repeat customer with Papanick. I couldn't be more satisfied. Jr. does it right! I'm sure others would also, but my experience has been with him. Ed in Mississippi
Ed
LAW OF MECHANICAL REPAIR
ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE
green30coupe is offline   Reply With Quote
Thread Tools
Display Modes
