06-09-2013, 11:23 AM | #1 |
Clutch or ????
Went solo 350+ miles in the mountains of Colorado the last 3 days... went over passes & roads that would make Henry proud. Was 5 blocks from home when I tried to shift... clutch pedal felt soft... stuck in 1st gear! 5-6mph the rest of the way home.
Linkage underneath looks OK. Plate on floor board lifted & I peaked inside-fork ok, nothing looked out of place. Clutch & pressure plate have less than 2k miles! Suggestions? Like pull the rear end, the tranny & check it out? Who sells best clutches & pressure plates... throw out bearing new last fall, 1600 miles ago at engine swap out & Mitchell OD added. thanks! Dave :-) |
06-09-2013, 11:45 AM | #2 |
Re: Clutch or ????
With the inspection cover, and maybe the floorboards, removed, depress the clutch pedal and watch for proper movement. If all is moving normally, it is likely something amiss in the pressure plate, although the disc could be coming apart too? You could have shifted gears without using the clutch by carefully adjusting the engine RPM to match road speed, as is done normally by double-clutching.
06-09-2013, 11:53 AM | #3 |
Re: Clutch or ????
Well I'm at the point where I need to repair. Plan is to order clutch & pressure plate, return what I don't need after pulling rear end & tranny for inspection. Trouble is our local 'experts' are all busy for the next 30 days! Prime driving time... I'm not confident in my own abilities or tools to do this. IF (if) I was to look for a local mechanic to (GULP) pay - how would I even look for someone? thanks! Dage :-)
06-09-2013, 11:54 AM | #4 |
Re: Clutch or ????
Thanks, Jim... any other suggestions? Dave :-)
06-09-2013, 11:56 AM | #5 |
Re: Clutch or ????
Look closely for a crack on the arm on the end of the clutch release shaft.
Tom Endy |
06-09-2013, 02:39 PM | #6 |
Re: Clutch or ????
Have helper press the clutch up and down while you look closely at arm under the car, like Tom and Jim mentioned. The crack will sometimes open up enough to see it when you press the pedal and then close up when you release it. |
06-09-2013, 02:58 PM | #7 |
Re: Clutch or ????
When I'm on the road I look up a local Snap On dealer. They usually know the better mechanics and might know one that works on vintage Fords. If I were in your area I would call Berts in Denver. That's probably the quickest place to get parts as well.
06-09-2013, 03:15 PM | #8 |
Re: Clutch or ????
The replacement lever arms are an UGLY thing but maybe a good thing to keep in your toolbox?
Hard to swing a hammer with the floorboards in place though. Didn't this used to be offered in a style with the shaft attached? Joe K
Shudda kept the horse. |
