Old 04-22-2011, 08:28 PM   #1
George, Iowa
George, Iowa's Avatar
Default What Model A part was the hardest to take apart?
What Model A part was the hardest for you to take apart? And what was your cure to get it apart?
I have taken the entire car apart!
Mine was the Model a hinge pins. Last one was finished with a cutting torch!
George, Iowa is offline   Reply With Quote
Old 04-22-2011, 09:05 PM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: What Model A part was the hardest to take apart?
Front wishbones were impossible to remove. So I left them alone.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 04-22-2011, 09:12 PM   #3
5window
5window's Avatar
I have not taken a whole Model A apart, but hinge pins were a bear. The top two,I had previously drilled out for hinge pin mirrors. The lower four, we had the doors off. It took two weeks of soaking with penetrating oil, heating with a torch, grinding the bottoms flat where they'd been peened over, driving with a pin punch,using one of Bob Drake's C-style pin pushers and finally, a great bit of advice.
Bob Drake's door pin removal tool: very sturdy, worked well on the one straight pin,but not well on the three bent ones. Plus, since BD makes parts for '32 and up cars, I found the push rod pins to be just a bit too big for the Model A hinges Not sure what size they really are,but a bit too big for Henry's just under 0.250 pins in my A. I used sawed off drill bits instead.
The great bit of advice came from Bill of Bill's Model A Acres in Watsontown,PA. I just happened to drop in for some other parts. He explained that the hinge pin can wear a step on one side and you have to get past the step to get the pin out. So I tried knocking the pin out with the door hinge opened to various degrees and finally found a spot where it pin didn't grip the walls of the hinge. Then it was easy (see above paragraph one)>
If you haven't been to Bill's it's worth the trip just to drool over all the stuff he has put away in his barns. Many thanks, Bill.
5window is offline   Reply With Quote
Old 04-23-2011, 12:25 AM   #4
JunkOSC
Removing the front spring perches...pain in the @$$!!!
JunkOSC is offline   Reply With Quote
Old 04-23-2011, 12:39 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
That's my vote!
Old 04-23-2011, 12:57 AM   #6
ratamahata
ratamahata's Avatar
All the front axle, front spring perches, the draglink and ties rods ends... and Rear brake track assembly make me sweating...
One day put some coca cola in the spring perches nuts, all night long the coke over the nuts and late the wrench is turned and them slip off... COKE? Donīt? Use oil
ratamahata is offline   Reply With Quote
Old 04-23-2011, 08:34 AM   #7
John Kuhnast
Bills Model A ? Does he sell parts? DO you have a phone number?
John Kuhnast is offline   Reply With Quote
Old 04-23-2011, 08:56 AM   #8
ratamahata
ratamahata's Avatar
Bill's Model Acres
Ford Farm RD 1 Box 283 8th St.
Watsontown, PA 17777 570-538-3200
Old 04-23-2011, 09:23 AM   #9
5window
5window's Avatar
Originally Posted by ratamahata View Post
Bill's Model Acres
That's it. Very nice guy-very willing to share his knowledge. There's Model A stuff all over the place.
Old 04-23-2011, 09:24 AM   #10
Terry, NJ
Terry, NJ's Avatar
Pa's a big state, Where's Watsontown?
Terry
[QUOTE=ratamahata;197528]Bill's Model Acres
Watsontown, PA 17777 570-538-3200[/QUOTE
Terry, NJ is offline   Reply With Quote
Old 04-23-2011, 09:43 AM   #11
Rowdy
I agree there. I had one I ended up drilling out. Too bad antiseize had not been invented when the A mas built. What a pain. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 04-23-2011, 10:04 AM   #12
Glenn C.
Glenn C.'s Avatar
I also go with the front spring perches. 20+ ton force which made a big bang.
Glenn C. is offline   Reply With Quote
Old 04-23-2011, 10:09 AM   #13
Sparky
Sparky's Avatar
I got lucky when I had to replace one of mine, it popped right out.
Sparky is offline   Reply With Quote
Old 04-23-2011, 11:41 AM   #14
Kevin in NJ
Perches go pretty easy with along throw mechanics air hammer. I have around a 3" throw hammer and put it against a solid surface. It took a little wait, but is started pushing through. Took the nut off when it got to the axle and continued through. The end was very slightly swedged out, but the nut still worked.
With all the correct tools, not much on the A is difficult. It is the correct tools part that is hardest as some can be pricey.
It is quite a challenge to get the stainless covers off the bumper clamps in a condition they will go back on. Had to make a tool to do this.
Kevin in NJ is offline   Reply With Quote
Old 04-23-2011, 11:57 AM   #15
Mitch//pa
[QUOTE=Terry, NJ;197547]Pa's a big state, Where's Watsontown?
Terry
terry,
its off rt 80 above harrisburg its not to far from us.
do a mapquest search of the town.
mitch
Old 04-23-2011, 01:59 PM   #16
reek29
reek29's Avatar
For me it was the kingpins. Used a hand sledge and pounded my #!% off!
reek29 is offline   Reply With Quote
Old 04-23-2011, 03:53 PM   #17
peters180a/170b
peters180a/170b's Avatar
i agree ,, front spring perches and shock covers..
peters180a/170b is offline   Reply With Quote
Old 04-23-2011, 04:41 PM   #18
George, Iowa
My front spring perches came right out? Maybe they were just so worn that they fell out. I did have a second runner up....a head bolt snapped off.
Old 04-24-2011, 11:06 AM   #19
5window
5window's Avatar
[QUOTE=Mitch//pa;197639]
Terry
terry,
mitch
Watsontown's also due north of Harrisburg off Route 15 North -probably a bit over and hour, depending on whether or not you can drive "Pennsylvanian". It's on the Susquehanna River. A nice little town. You'd be about exit 212 if you're getting off I-80.
Old 04-24-2011, 11:23 AM   #20
kp
kp's Avatar
Got to agree with Peters 180/170b,shock covers are a bitch ,I used pipe wrench with 3 foot cheater .
kp is offline   Reply With Quote
