Old 02-20-2011, 06:45 PM   #1
George, Iowa
George, Iowa's Avatar
Default Taking Doors Off - HELP
What is the best hinge pin tool?
Mac's tool V46335pull
or
Snyders tool A-46335-T
OR is it easier to take off the door hinge to body screws.
BOTH door hinge pins and body screws are rusty. I am soaking them with Kroil Oil.
Thanks for any advice on getting the doors off.
George, Iowa is offline   Reply With Quote
Old 02-20-2011, 06:56 PM   #2
Colorado Greg
Colorado Greg's Avatar
Default Re: Taking Doors Off - HELP
I would go with the Snyder style tool. I had some very stuck pins and I soaked them for a couple of weeks before trying to remove the pins. It was still a bugger with the heavier duty tool. I actually purchased mine from Berts in Denver and don't remember paying that much for it.
"Betsy doesn't leak oil - she just marks her spot"
Colorado Greg is offline   Reply With Quote
Old 02-20-2011, 07:01 PM   #3
George, Iowa
Did you add any heat to them before spraying them? Or did you add heat as you were taking them off with the tool?
Old 02-20-2011, 07:04 PM   #4
Colorado Greg
My car was already painted and I was only adding mirrors. I didn't want to ruin any of the paint so I did the whole process cold.
Old 02-20-2011, 07:06 PM   #5
George, Iowa
Thanks Greg! Anyone else have some advice?
Old 02-20-2011, 07:09 PM   #6
Doug in NJ
Doug in NJ's Avatar
I unscrewed all my sedan hinges (partly because the screw heads were ugly-looking from previous owners trying unsuccessfully to remove them). It took a combination of Kroil, an impact wrench with a screwdriver blade, and ithe "blue wrench" (an oxy-sctelyene torch) to get them all out. Taking out the hinge pins was a bit easier when the doors were on the workbench. I used a nicely-made C-clamp style tool that I got at a swap meet.
Also, for the S/W sedan, finding correct replacement screws and washers was not trivial.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 02-20-2011, 07:17 PM   #7
George, Iowa
Doug, I thought that blue wrench might make things go better. :-) Thanks for the advice.
Old 02-21-2011, 01:08 AM   #8
Doug in NJ
Doug in NJ's Avatar
I've never welded anything with my torch (one of those portable mini-sets from Lowes or HD), but it has been incredibly useful for loosening things and brazing.
Doug
Thread Tools
Display Modes
