07-14-2021, 12:54 PM | #1 |
Those early FORD GAS GAGES
I have done the search for the fluid etc for the 32 ford gas gauge and coming up empty. Mac`s is on a 2month wait, and A & L Parts doesn`t have a good ph or contact info. Looks like they mention they are wholesale only now as well. Anyone have a source for the red fluid? Thanks
07-14-2021, 02:13 PM | #2 |
Re: Those early FORD GAS GAGES
https://www.chamberofcommerce.com/un...ts-specialties
A & L Parts Specialties is located at Po Box 301 in Canton, Connecticut 06019. A & L Parts Specialties can be contacted via phone at (860) 693-0112 for pricing, hours and directions. |
07-14-2021, 02:31 PM | #3 |
Correct, A & L only sells to dealers now.
07-14-2021, 02:58 PM | #4 |
I bought 4 ounces of red gauge fluid on EBAY for 16.95.
This is the same stuff the vendors are selling in those micro bottles for 6.95. It has worked OK for me so far. You could probably fill 100 of those tiny bottles. |
07-14-2021, 03:10 PM | #5 |
Some reading...
https://packardinfo.com/xoops/html/m...&post_id=70322
07-14-2021, 05:13 PM | #6 |
07-14-2021, 05:59 PM | #7 |
Yes indeed cas3, it is not just old Fords that need this stuff, other brands ran the same system and the owners have the same need of a good, quality liquid for their fuel gauges. Tetra-bromo-ethane, with a specific gravity of 2.95, dyed with Durant scarlet dye, was the original formula. The alternative dye mentioned in the above article, would appear to be a good color fast substitute for the Durant stuff.
07-14-2021, 06:03 PM | #8 | |
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
07-14-2021, 07:45 PM | #9 |
Karl, It's a fancy, colorful label on the original Ford bottle isn't it?
07-15-2021, 12:11 AM | #10 |
I had one of those small bottles I found on EBAY also.Yes the graphics are very nice. Here is a pic of the fluid in comparing with what is offered today.On the left that I have is the orig from that bottle and on the right the new stuff.The new is whats comes in the line kit from vendors.After 3 yrs in the '33 I once owned it (orig)did not fade,in fact its almost to dark.
07-15-2021, 12:49 PM | #11 |
I have some that a friend said was original stuff. Used it and it lasted several years before going clear. It is dark as noted above rather than brighter red . I also recently bought some of the newly available fluid from one of the specialtly vendors mentioned here on the Fordbarn for $25. It lasted about 2 months before going clear. My best advice is to get the special hex/barrel nuts from Mike Driscoll so you can easily remove the gage periodically and refresh it with a hobby syringe. For the fluid, use what you can get and change it when clear. Not a great solution, but the barrel nuts make it way better, especially on a duel temp gage.
07-15-2021, 09:17 PM | #12 |
how do i refill a '36 gas gauge? or is that even a DIY project? looks like both ends of the thin reinforced tube are soldered on.
07-15-2021, 11:41 PM | #13 |
First,'36 had an electric gauge,Not hydrostatic. Second ,you fill in the brass hex on back of gauge and if the line to the glass tube is clean(incl glass tube) the fluid will appear. Pictured is the back of an orig 32 gas gauge.That thin line must be clear(clean) all the way to the glass tube in the gauge housing.Acetone and or brake clean helps unclogging sometimes.
07-16-2021, 10:28 AM | #14 |
jdpaxton, I don't know where you live but I have a bottle of the original Ford fluid. If you were within driving distance I could help you out. It is illegal to ship the original substance. See the picture in my Misc album. This fluid is still as red as the day it was made 90+ years ago.
07-16-2021, 11:12 AM | #15 |
Just looked at your Misc album. That is exactly the same bottle I got off an EBAY auction years ago. The darker fluid in post #10 is what's left that I still have. I donated the empty bottle with its box to The Early Ford Store.
07-17-2021, 02:19 PM | #16 |
I used the product that came from Macs still good ,I think its all about the clean ,(contaminates ) take a photo for future use ,
