Old 04-22-2014, 03:51 PM   #1
1949FORD
1949FORD's Avatar
Question Well that's weird...
Okay, so... I start up the 49 today and drive it out of the garage. I let it warm up at idle for a couple of minutes. I open up the hood and i find smoke/steam coming up out of the oil fill cap. I don't know if i should be worried, because i've never seen this before in my life. Any help will be appreciated!
1949 Ford Fordor
2001 GMC Sierra SLE
Joshua Landvik
1949FORD is offline   Reply With Quote
Old 04-22-2014, 04:02 PM   #2
Chris Nelson
Chris Nelson's Avatar
Default Re: Well that's weird...
Check the level of oil in the engine and the level of water/antifreeze in the radiator. Look for water droplets on the dipstick and is the oil gray in color. If so, you have water in the oil.
Chris Nelson is offline   Reply With Quote
Old 04-22-2014, 04:04 PM   #3
1949FORD
1949FORD's Avatar
okay thank you! i will do check on that
1949 Ford Fordor
2001 GMC Sierra SLE
Joshua Landvik
Old 04-22-2014, 04:07 PM   #4
ford3
another quick check is to see if the smoke is blue or white, white is water vapor, blue is oil smoke, but what ever you do dont panic and start taking things apart, retorque heads after engine cools off then see if it happens again after changing oil, put in some cheap stuff because your only trying to see if torquing heads worked, you will need to drain that oil out right away because there will be some water in it from being left over in the engine
ford3 is offline   Reply With Quote
Old 04-22-2014, 06:17 PM   #5
1949FORD
1949FORD's Avatar
Looks like i'll have to do what you suggested, ford3. Pulled the dipstick to recheck the oils color and yep, ive got water in there. Thanks guys for helping me out!
1949 Ford Fordor
2001 GMC Sierra SLE
Joshua Landvik
Old 04-22-2014, 06:42 PM   #6
Mike51Merc
Mike51Merc's Avatar
Springtime brings days of rapid temperature swings around the dewpoint when condensation happens most. Cold nights and warm days. It could be that your engine just needs a good run on the highway to steam off the condensate.
Like Ford3 said, drain the oil, paying close attention to what comes out first. If it's a lot of water or your oil has turned to gray mayonnaise you might have a more serious problem. If it's just a little water and the oil looks good, then put fresh oil and monitor the situation closely.
Mike51Merc is offline   Reply With Quote
