06-03-2013, 03:29 PM | #1 |
wcfb on flatty 4-b intake
bought an anderson 8-ba 4-b intake last weekend at york; has a carter wcfb carb on it, main body casting is 0-981, air horn is 6-1008. any body here privy to what this carb would have come on originally ? thanks
06-03-2013, 03:58 PM | #2 |
Re: wcfb on flatty 4-b intake
A pic would help.
06-03-2013, 05:06 PM | #3 |
wcfb=will carter four barrel. Corvettes had them prior to 1963. Cast iron?
06-03-2013, 05:16 PM | #4 |
57 Chey with 2 fours. Charles
06-03-2013, 06:16 PM | #5 |
Henry Ford designed the flathead without the aid of a computer. |
06-03-2013, 07:26 PM | #6 |
06-03-2013, 09:53 PM | #7 |
WCFB=wrought cast four barrel , AFB=aluminum four barrel (first used on 327 in 62) Both are Carter carbs
06-03-2013, 10:13 PM | #8 |
Nice to use the Text to speach program of these new computers to read all that fine print.
06-03-2013, 10:43 PM | #9 | |
Just showing how computer Savvy I am --- NOT --- You mean that there is a program that will read the printed text for us ?????? If so what's it called / who makes the program ? |
06-03-2013, 10:54 PM | #10 |
I wonder what WCFB really does mean. I thought it was White Cast Four Barrel, but there seem to be a lot of choices here. They are good carbs anyway.
06-04-2013, 12:37 AM | #11 |
06-04-2013, 05:30 AM | #12 |
WCFB was an early four barrel used primarily on GM products such as Cadillac and others with OHV V-8s. If it has the early small bolt pattern, it was prior to about 1956. After that, the bolt pattern was enlarged. GM and some MoPars also used these in their 2-4 applications. God only knows what else they may have been used on(I believe Studebaker may have used them in some cases). I believe that some of the later 2-4 applications may also have had the small bolt pattern, but not positive about this.
The key to application is the numbers you have identified here. If go to e-bay and look up wcfb, you will see a number or rebuilders/dealers on there that, if contacted, may help you out. I do know in trying to locate one of these(small bolt pattern) in the past for use on my flathead that they are fairly precious; even in rebuildable condition. There is a 2-4 set for a Chevy listed as rebuilt for $4200.00 right now. As wga said, a small bolt pattern WCFB in good condition would be perfect for a flathead. |
06-04-2013, 06:03 AM | #13 |
here is my setup edelbrock manifold and I believe a 52 olds wcfb carb
06-04-2013, 07:01 AM | #14 |
thanks for all the responses. wga sent the link to "the carburetor shop" which was great. 222 different wcfb models !! who knew? mr. texas nailed the wcfb; will carter four barrel. mine is aluminum.
06-04-2013, 07:33 AM | #15 |
WCFB=Will Carter Four Barrel
06-04-2013, 08:18 AM | #16 |
06-04-2013, 05:29 PM | #17 |
Yes, the text to speech program came with the windows XP. (I think) And you can find it in the accessories.
I have mine setup to start automaticly when the computer boots up in the morning. Yje all I have to do is highlight any text, hit crl+F9 and the computer reads the text. You can buy other voices and feachers. |
