12-16-2013, 10:57 PM | #1 |
help...info..input...4 banger to flathead v8 conversion
I have a 31 open wheel model a ....an just came across a great 1948 flathead v8 motor an tranny...question is degree of difficulty to make the swap an tork tube ...are they the same in general...mayb just have to shorten?? All input would be greatly appreciated...thanks guys..friend me on fb...derekswackygarage....
12-17-2013, 06:37 AM | #2 |
Re: help...info..input...4 banger to flathead v8 conversion
Welcome to the barn. Take a look at the forum jump below and try the hot rod forum. It will take you to the HAMB where there is a wealth of info. Short answer is no its not difficult, lots of variations, and it can bolt right up to a stock torque tube.
12-18-2013, 10:33 AM | #3 |
its not too bad,
i did a 37 flathead in my 30 model a... shorten the torque tube, fab motor mounts, trans mount, fab pedal brackets. install a f1 box.. split the whish bones. fabricate ebrake system.. hydraulic brakes.. or you cen go through snyders and get the bellhousing bracket to use the stock pedals on a v8 trans. thats a cool way to do it also. there is a link to my model a build on the hamb: http://www.jalopyjournal.com/forum/s...d.php?t=772500 |
12-18-2013, 10:38 AM | #4 |
There are so many variables depending on what you want your finished product to be, but generally the swap isn't too bad. Definitely head over to the HAMB, these swaps have been covered thousands of times.
12-18-2013, 01:16 PM | #5 |
No you do not have to shorten the torque tube. Steering gear, motor mounts, clutch and brake pedals, maybe fire wall will rub. They are the biggest problems. Use a 39 transmission.
12-18-2013, 08:02 PM | #6 |
http://www.verntardel.com/collection...l-ford-hot-rod John |
12-22-2013, 08:02 PM | #7 |
Thank you everyone whith my question....im new to this site an was nervous on posting in correct spots... thank you all for being so nice an helpful to me...I will post pics soon....i have done so many muscle cars....im done...fell in love with model a's....as long as they are traditional builds....
Thanks again Derek |
12-22-2013, 08:17 PM | #8 | |
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
12-22-2013, 11:25 PM | #9 | |
12-23-2013, 10:14 AM | #10 | |
why not on this forum? check out the V8 side on what is talked about there. Juice brakes, T5 transmissions, bigger cams, headers , multiple carbs, the list goes on and on.
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
12-23-2013, 10:57 AM | #11 |
The v8 side is a lot more laid back but the hamb has a lot more info.
12-23-2013, 08:12 PM | #12 | |
lets see them hear!
