08-23-2011, 01:50 PM | #1 |
Original 1940 Ford Banjo Rear Gear Set 3:54 Ratio
City:
St. Louis
State:
MO
Price:
250
I have a set of original hard to find 3:54 gears removed from a 1940 Ford. Included is the banjo center section, ring and pinion, and axle shafts. I have no idea of the condition of bearings etc... The faces of the teeth do have some pitting on them. I have never run this set of gears, it came with a parts car I purchased.
$250 Will remove axles for shipping |
08-24-2011, 06:39 AM | #2 |
Re: Original 1940 Ford Banjo Rear Gear Set 3:54 Ratio
hi--would you inc. ship to Bel Air, Md. 21014 ? do you have pic. of numbers on underside ? thanks, Bruce (410) 879 8039H [email protected]
08-24-2011, 01:45 PM | #3 |
Hello- I'll take the rear if its still available. How much to ship to NY 11715? Thanks. Bud
08-24-2011, 10:05 PM | #4 |
Web of housing is stamped 11 39. Counted teeth and it matches 11 on pinion and 39 on ring. Stamping will not show up on photograph.
No idea on shipping yet. I will have to remove the axle shafts and weigh it. |
08-25-2011, 02:52 PM | #5 |
