Old 04-03-2011, 08:06 PM   #1
jhstal
Default 1938 Ford hood prop
1938 Ford tudor sedan. I am missing something on my hood prop, the lower hole in the hood prop assembly that lines up with the cowl pinch flange with a shouldered bolt has a large hole the size of dime, the bolt is 1/4", shoulder is 5/16 on bolt. Is there some type of special washer-bushing, guide?? that fills hole, mine is very loose on shouldered bolt. Upper mount on hood is correct and ok. John
jhstal is offline   Reply With Quote
Old 05-18-2011, 12:56 PM   #2
[email protected]
Default Re: 1938 Ford hood prop
John:
I seem to have somewhat the same problem as you. I have a 38 Tudor Sedan that's only got chrome hood hinges and no prop at all. I've been trying to find out exactly what's required to prop the hood open. I'm currently using a wood pole.
thanx
rwolak@verizon.net is offline   Reply With Quote
Old 05-18-2011, 02:20 PM   #3
Bruce/Texas
My '39 standard (which should be the same as the '38 deluxe) has a 1/4" diameter hole on the pinch flange on the cowl. The 5/16" shouldered bolt with 1/4-20 threads fits with normal clearance into the hole in the cowl with a lock washer and nut pointed inboard. Assuming your dime size hole is round, it may have been drilled out due to being worn. Welding a plate over the hole and re-drilling the 1/4 hole will work or possibly welding a dime sized washer in the hole will work as well.
Bruce/Texas is offline   Reply With Quote
Old 05-18-2011, 02:53 PM   #4
40cpe
40cpe's Avatar
Those factory props are a kinked hood waiting to happen. If you are not concours, fabricate a 1/4" rod the length you want the hood to open. Put a 90 degree bend in the bottom 3/4" with a cotter pin hole. Insert this through the hood side/radiator tabs and insert the cotter pin. Weld a stop (nut, washer, etc) about 3/4" down from the top of the rod. Drill a 1/4" hole in the turned under lip of the hood above the new hood prop. Fabricate a holding bracket for the new prop along the hood side and you're done.
Old 05-19-2011, 09:05 AM   #5
Planojc
Planojc's Avatar
As 40 cpe mentioned, almost all those style hoods get kinked in the area of the hood prop. Prior to painting the hood on my 39 Std.,I welded a 1/4 " piece of angle iron about 8" long to the top of the hood flange and the curved side, in the area where they kink. You would have to look really hard to see it.
Planojc is offline   Reply With Quote
Old 05-19-2011, 11:19 AM   #6
Clem Clement
Clem Clement's Avatar
My '39 pickup uses a brake rod for a hood prop. It pivots in an already-there hole next to the hood latch and sets in a hole under the hood. It has rubber hose over the rod and lays quietly on a radiator support rod.
Old 05-19-2011, 07:11 PM   #7
39 STD
39 STD's Avatar
On my 39 Std, as said, both side of the hood were kinked &/or split, from the hinge mounts. I have'nt installed my hood yet but I thinking of using some kind of prop.
God is great, beer is good -----People are crazy
39 STD is offline   Reply With Quote
Old 02-13-2012, 12:41 PM   #8
beauishere
beauishere's Avatar
I have the same problem with our 1938 tudor deluxe. Despite all the previous guesses, does anybody actually know the answer? The '38 is not the same as a '39. A shoulder bolt would make sense, but I haven't got a picture to verify.
Any real help would be appreciated. We're trying to stay stock and figure that if the hood lasted this long, then with a little restoration, the stock prop isn't gonna do any damage.
Thank you.
'da Hui no ka oi !
http://www.themilnercoupe.com/
beauishere is offline   Reply With Quote
Old 02-13-2012, 12:47 PM   #9
Seth Swoboda
Seth Swoboda's Avatar
There is a sliding mechanism that mounts to the drivers side of the cowl section and on the hood. When you open the hood it slides up and into a notch and then you turn the stop on the slide to hold up the hood. That is why the hoods on the standards and pickups for 38-39 have a stress crack or are bent in that location.
Old 02-13-2012, 02:10 PM   #10
Jack E/NJ
Jack E/NJ's Avatar
Broom handles can be tailored to custom fit just about any year hood. 8^)
Jack E/NJ
Old 02-13-2012, 05:51 PM   #11
40cpe
40cpe's Avatar
Thank you.
Aside from my post above, I can only look at the mounting hole on my '38 and tell you its size. I'll look tonight and report.
Old 02-13-2012, 08:30 PM   #12
Seth Swoboda
Here are a few pictures of the part you guys are looking for.
Old 02-13-2012, 10:07 PM   #13
40cpe
40cpe's Avatar
The hole in the flange on my car will accept a 1/4" bolt but won't allow a 5/16" to pass. A dime-sized hole would take up the whole width of the flange.
Old 02-13-2012, 10:38 PM   #14
felix37
felix37's Avatar
Jack E/NJ
That's what I'm sporting! as the original had almost ruined my hood. A good judge should add points to those who removed the original hood latches on 37,38's. Ha Ha
felix37 is offline   Reply With Quote
Old 02-14-2012, 07:38 AM   #15
jhstal
38 Ford hood prop, the large hole in the bottom of the prop is filled by a factory rubber hard bushing and inner sleeve, you have to make it, it was not designed to be replaced, came with new hood prop.
Old 02-14-2012, 08:53 AM   #16
40cpe
40cpe's Avatar
That must have been a running change. What did the '39 have in that hole?
Old 02-14-2012, 01:55 PM   #17
jerry grayson
That is good for a 38, but 39 std is completly different.
jerry grayson is offline   Reply With Quote
Old 02-14-2012, 02:03 PM   #18
Seth Swoboda
Jerry,
I was not aware of that. What did the 39 standard look like, how was it different from the 38 prop that I have? I was planning on using that prop on my 39 pickup.
Thanks, Seth
Old 02-14-2012, 04:03 PM   #19
jerry grayson
Seth
I do not know if the pickup prop is the same as a passenger car or not and I don't have a photo of a 39 car. I sold my 39 standard coupe so can't take a picture of it.
Old 05-26-2016, 08:28 AM   #20
alucchetti
does anybody have a picture of the 1938 hood prop rod mounted in a car?
alucchetti is offline   Reply With Quote
