07-21-2011, 10:20 PM | #1 |
Rotary "00" Grease
Today I bought a 32 oz. bottle of Rotary "00" Grease ($10) from a Snapper Yard Eqmt dealer. it refers to Glennville, Ga.
A place on internet says Rotary is same as Amsoil. (?) Anybody know if this is good stuff? thank you, fordman |
07-22-2011, 01:43 AM | #2 |
Re: Rotary "00" Grease
Uhh, I'm trying to understand the situation here... You bought some grease, you don't know who makes it, or if it is good stuff?
Alan |
07-22-2011, 07:25 AM | #3 |
the continuing sage: there has been much discussion about selecting good lubricant for the U-joint. Chevron ep-00 lithium based grease was recommended but alas, they only sell it in 5 gal. buckets.
00 grease is very thick at room temp and almost has no leakage; when it begins to warm up, it flows into the u-joint to produce efficient lubrication. I was delighted to find a 32 oz. bottle for $10. sorry about the lack of info, fordman |
07-22-2011, 08:58 AM | #4 |
I have serviced mowers using the OO grease for 50 years, it is GOOD stuff my current mower is a 66 model 30 in cut , tranny and gears are untouched still working great. works in my 46 u joint also , ernie n tx
07-22-2011, 10:14 AM | #5 |
The thing you should check is if it is lithium based -as opposed to urea based like cornhead grease . Cornhead grease also is "0" viscosity and is not fluid . "00" viscosity IS FLUID . The stuff in the pic is $7.99 @ qt at the local John Deere dealer . I use this stuff in my old John Deere tractors steering gears and mixing a couple quarts in with the tranny fluid really quiets the all straight cut gears down . Never used it in my Fords as I like 140 gear lube in steering.u-joint,tranny and rear end . IF I was going to use something other than 140 in the steering & u-joint this would definately be it . Sounds like what you have there and what I posted pics of are the same IF yours is lithium based . Ed Solari talked much about this stuff and the fact that using urea based cornhead grease in the u-joint and lithium based gear lube in the tranny as these intermix wether you want them to or not . Mixing urea & lithium based stuff isn't the best idea .
07-22-2011, 10:20 AM | #6 |
07-22-2011, 04:07 PM | #7 |
Just for information, the most common use years ago for the 00 Lithium grease was in the track rollers of crawler tractors. That's what it was developed for.
