06-11-2018, 08:19 AM | #1 |
48 F1 Dana 41 need bearing cup number help please
Guy's I am rebuilding the Dana 41 rear end from my 48 F1 . I have the number of every bearing & cup except for the big pinion bearing cup ?
There is no number on the old one. The bearing is a Timken 31593 Could also use a supplier for the shims. Thanks in advance for any help!!! Cheers Tony |
06-11-2018, 10:03 AM | #2 |
Re: 48 F1 Dana 41 need bearing cup number help please
If you have a local bearing supplier they should be able to match it.
06-11-2018, 10:56 AM | #3 |
Contact Randy's Ring and Pinion. Excellent folks and outstanding service.
https://www.randysworldwide.com/ |
06-11-2018, 12:27 PM | #4 |
Hi Tony, cup number should be a 31520-B??
Thanks, Gary in N.Y. P.S. The number for the entire bearing series is 31500, reasonably sure this is all correct??
http://www.stromberg-bulletin.com/me...berg-equipped/ |
06-11-2018, 12:26 PM | #5 |
8A-4628 is the OEM number. I think the Timken number is 31520. They should be same for Dana 44 so they were used a very long time by lots of manufacturers.
06-11-2018, 12:55 PM | #6 |
Cheers Tony |
