Old 11-17-2020, 03:45 PM   #1
franksford
Default polarizing a generator
This is a continuation of the post I submitted other day. I'm attaching the instruction sheet that came with a new NOS regulator, I hope.
NOTE: the polarizing instructions are for a type "A" winding, FLASH ARMATURE TO BATTERY not the standard type "B",FLASH FIELD TO BATTERY. Question, does the regulator care if its a type A or B winding and did ford ever use type A in the late 30's, early 40's?
Can not upload, why???
So the burning question now is. Does the regulator care if the gen is a type A or B winding?? And how do i upload a file??
Thanks
Frank
franksford is offline   Reply With Quote
Old 11-17-2020, 03:54 PM   #2
JSeery
JSeery's Avatar
Default Re: polarizing a generator
Yes, type B is different and the only type a Ford used, that I'm aware of, except some A were used on tractors.
Old 11-17-2020, 04:58 PM   #3
51woodie
51woodie's Avatar
Here is a copy of the instructions I have. Judging by the three languages, I would say it is for an aftermarket unit, but may be what you need.
51woodie is offline   Reply With Quote
Old 11-17-2020, 05:35 PM   #4
koates
The instruction sheet that came with your regulator indicates it is for a type A circuit and therefore you cant use that regulator with any Ford generator made from 1939 onwards. Ford generators are type B field circuit and require only a type B voltage regulator. Make sure those instructions are the ones that belong to that regulator. Check the part numbers on the reg and on the sheet. Regards, Kevin.
koates is offline   Reply With Quote
