06-08-2021, 06:50 AM | #1 |
272 Spark plugs
OK, so Autolite 46 is what I need- are those easily available at current auto parts stores ( advance; autozone, etc ) ? and if not, I have heard that NGK is a good plug but I can't find the specific NGK crossref from the 46. Anyone know the NGK number?
06-08-2021, 09:07 AM | #2 |
Re: 272 Spark plugs
***** - DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
06-08-2021, 11:14 AM | #3 |
Re: 272 Spark plugs
The NGK WR5 is an approximate. It has a slight V-cut in the tip of the electrode.
06-08-2021, 07:52 PM | #4 |
Re: 272 Spark plugs
I got 46s at AutoZone or Advance, can't remember which but they have 'em.
Often wrong but never in doubt. |
06-09-2021, 01:53 AM | #5 |
Re: 272 Spark plugs
Unless you would rather have MOTORCRAFT....
Since they broke apart from one another, MOTORCRAFT remained Quality, while Autolite became the "bottom of the barrel".... I have MOTORCRAFT, if you would like..... |
06-09-2021, 06:57 AM | #6 | |
Re: 272 Spark plugs
I used to run Motorcraft BSF82C...not sure where I could get those. |
06-09-2021, 10:04 AM | #7 |
Re: 272 Spark plugs
AUTOLITE-HONEYWELL produces the bulk of MOTORCRAFT SPARK PLUGS (USA).
They are manufactured to FORD SPECS and I doubt FORD will allow the exact same product to be sold under another trade name. FORD MOTOR is not the FOMOCO that used to be. It is a world wide auto manufacturer and has many suppliers, many of them overseas. What you buy now marked FORD and/or MOTORCRAFT is a crap-shoot. Most everything produced today is either ASIAN or EUROPEAN design. FORD has a huge manufacturing plant/foundry/assembly in CHINA now after closing the facilities in AUSTRALIA. Hey, no IRS, OSHA, wage - health care - comp - retirement or unions. I remember ... ... reading a post a few weeks ago where the poster said the plugs he bought were CHI-COM. Can't remember ... ... if they were AUTOLITE or CHAMPION. READ HERE - https://findanyanswer.com/are-motorc...olite-the-same CORRECTION - AUTOLITE is now owned by TRICO GROUP - https://www.aftermarketnews.com/tric...-and-autolite/ No 55blacktie, CHI-COM is not a racist term, it is reality.
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 06-09-2021 at 02:17 PM. Reason: I POSTED A MISNOMER |
06-09-2021, 01:12 PM | #8 | |
Re: 272 Spark plugs
Thanks for the heads up on that, KULTULZ. |
