Old 05-29-2021, 06:10 PM   #1
Pre1898
Pre1898's Avatar
Default Help ID this Rear End Please
A friend was cleaning up his property and gave me this rear end / front end but not sure what year it is ? He thought 36 1/2 ton pickup but not so sure ???
Thx dusty
Pre1898 is offline   Reply With Quote
Old 05-29-2021, 06:23 PM   #2
Andy
Default Re: Help ID this Rear End Please
Looks like 39 to me.
Andy is offline   Reply With Quote
Old 05-29-2021, 06:33 PM   #3
Ggmac
I was going to say 40-41 . 39 has got wide 5 bolt so it could be . Im sure someone with more knowledge will chime in . If you can post pics of the spindle back , round or squared , and the drums , if it has any will help .
Old 05-29-2021, 06:35 PM   #4
Andy
The first pic shows wide five. Wide five and hyd. brakes 39 only
Old 05-29-2021, 06:40 PM   #5
Pre1898
Pre1898's Avatar
More pics attached. Thanks.
Old 05-29-2021, 08:51 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Must agree with "Andy" ......the two assemblies LIKELY came out of a '39, if not assembled from parts.
But here is a breakdown of the individual pieces that WILL interchange easily.
Drums are 1937-'39. '36 FRONTS would not fit that spindle.
I-beam ....'37-'41.
Wishbone ....'37-'40.
Spindle ....'37-'40. (Drag link fitting from bottom indicates NOT '41)
Backing plates ....'39-'41.
Rear end ....Could be '37-'40. Drilled radius rods (for clamps) indicate '39-'40.
Rear radius rods/torque tube ....'37-'40 (as pictured)
Click Links Below __
T5 W/TORQUE TUBE
Old 05-30-2021, 12:11 AM   #7
bbrocksr
Looks like Andy got it .
Bill
bbrocksr is offline   Reply With Quote
Old 05-30-2021, 10:06 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Those front & rear assemblies could have been previously used under a '36 1/2 ton pickup, since they will bolt right in place, but they are most likely both originally from a '39 passenger car or light commercial vehicle.
It would be interesting to see what gear ratio is in the rear.
John
Old 05-30-2021, 11:54 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by JM 35 Sedan View Post
Those front & rear assemblies could have been used under a '36 1/2 ton pickup, but they are most likely all originally from a '39 passenger or light commercial vehicle.
As noted up in post #6, '36 drum won't fit the ROUND '37-'40 spindles....the LONG snout. '36 FRONT drum (left) is a "ONE-year-only".
'36 REAR end radius rods (just like YOUR '35s) BOLT-ON to flanges welded to the axle housings...'35-'36-ONLY.
Old 05-30-2021, 01:28 PM   #10
Ggmac
You are correct, I completely missed it .
Old 05-30-2021, 03:38 PM   #11
JM 35 Sedan
Coopman, I think you misunderstood or misinterpreted what I said in my post #8. Going back to the original post, Pre1898 said the guy who gave him those assemblies, (his friend), "thought" they may have been '36 1/2 ton pickup.
What I said was those assemblies could have been "used" under a '36 pickup, ....meaning someone could have assembled the complete '39 front end and rear end "assemblies" under a '36 pu, because they will fit and bolt right up, and would be a quick way to get hydraulic brakes.
I realize that '36 front drums won't work on '37-'40 spindles, and '35-'36 rear wishbones are different from '37-'40 rear wishbones, and bolt to rear differently.
John
Old 05-31-2021, 06:31 PM   #12
Pre1898
Pre1898's Avatar
Thanks everyone for the kind help very much appreciated !!!
