08-22-2012, 11:28 AM | #1 |
Chasing Windshield Leak
The other night I got caught in a pretty heavy downpour and ended up with a lot of water leaking into the cab of my pickup. Looks like I have all the needed gaskets, but I've posted a bunch of pictures and was wondering if anyone can tell me if I'm missing some or if I just need new ones?
Thanks in advance for any input.... Scott |
08-22-2012, 03:20 PM | #2 |
Re: Chasing Windshield Leak
I really don't have much experience with windshield leaks but I imagine it would help to know about where the water was coming in at and at what speed maybe it occurred.... Good luck.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
08-22-2012, 04:31 PM | #3 |
My windshield seals look a little thicker than yours, or maybe it's just hard to see in your photos.
Ray White |
08-22-2012, 05:50 PM | #4 |
The panel above the W S appears to be missing a number of nails that fasten it to the wood header.That would allow water to run betweem them in a heavy rainstorm.
08-22-2012, 06:01 PM | #5 |
Thanks. I'll remove the visor and use some tacks to fasten that. Are there special nails I should use?
08-22-2012, 06:29 PM | #6 |
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
08-22-2012, 07:20 PM | #7 |
I had several nails missing on the upper panel & I replaced them with 3/4" spiral body nails by installing them on a slight angle with a rod with a shallow concave hole in the end & long enough to clear the front of visor,then used the hammer to install.There was no need to remove the visor as the top material is nailed thru slots in visor.
08-22-2012, 07:25 PM | #8 | |
03-26-2017, 05:53 PM | #9 |
You might try using a lawn blower or shop vac outlet side and pinpoint the area with someone on the inside locating the place or places
the air is getting in. May have to remove a portion of the headliner if you can't see the inside. Soapy water may help depending on size of leak |
