12-30-2023, 08:41 AM | #1 |
Pinion removal
Looking to remove pinion out of 48 ford rear. Any & all suggestions appreciated
Happy New Year Thanks, Rick |
12-30-2023, 12:03 PM | #2 |
Re: Pinion removal
It's a press fit. Removal and reinstall can both be done with a press.
Alan |
12-30-2023, 12:27 PM | #3 |
Re: Pinion removal
Thank you,
Happy New Year |
12-30-2023, 01:04 PM | #4 |
Re: Pinion removal
Subject was posted here. Do a search -box in upper corner. Newc
12-30-2023, 01:23 PM | #5 |
Re: Pinion removal
Easy to do with a hydraulic press - also a bit of heat around the outside of the banjo casing helps a lot.
12-30-2023, 07:55 PM | #6 |
Re: Pinion removal
