Old 05-22-2022, 11:20 AM   #1
jetmek
Default ARP main bearing bolts
Has anyone had any trouble using these lately? I have in the past but the ones i just got apart from being 1/4 inch too long( no biggie) the threaded part bottoms out in the block way before contacting the washer. They are 1/2-13 x3. Im not keen on removing threads from the block in order to get the bolt to seat. Btw its a 42-48 block. Thanks
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 05-22-2022, 09:31 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: ARP main bearing bolts
Why do you think you need ARP bolts there instead of the stock studs?
Old 05-22-2022, 10:05 PM   #3
Pete
Pete's Avatar
Stock studs will work up to horsepower levels you would have to mortgage your house to afford..
Old 05-23-2022, 10:02 AM   #4
jetmek
Thanks for the opinions but they dont answer the question
Old 05-23-2022, 10:21 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
"Has anyone had any trouble using these lately?"
This is the only question you asked, to that I say no.
Old 05-23-2022, 10:35 AM   #6
deuce_roadster
Neither did you. I am curious as to what is causing this need.
Old 05-23-2022, 11:01 AM   #7
jetmek
Thanks. Just curious as i have not had issues with them in the past. Your tag line seems applicable here 51 merc
