03-30-2022, 03:33 PM | #1 |
46 Ford sedan coupe top of door seal question
Is the “top of door seal” (weatherstrip)on a 41-48 long door coupe or Tudor sedan glued to the door opening or is it glued to the door ? Thanks in advance
03-30-2022, 05:56 PM | #2 |
Re: 46 Ford sedan coupe top of door seal question
On the Tudor it is attached to the door jam.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-30-2022, 06:08 PM | #3 |
03-30-2022, 10:00 PM | #4 |
1 on hinge siide of door & 1 on latch side plus a short seal at the bottom tha wraps around to the inside. BTW I checked Bob Drake's website and it appears that all the door seals go on the door. I had better luck with the top door seal on the body of our '41.
03-31-2022, 08:27 AM | #5 |
