08-23-2018, 07:53 PM | #1 |
Painting Engine Pans
Painted my original engine pans a nice gloss black. Knew I had a few carb drips so I protected the paint. Well I didn't protect it enough and it wrinkled my new black paint.
What paint type/brand should I be using on the pans that will handle a small amount of gas drip once in a while? Need to be a true gloss black--- not the grayish gloss black restoleum sells. Thanks |
08-23-2018, 08:00 PM | #2 |
Re: Painting Engine Pans
have them powder coated.
08-23-2018, 08:18 PM | #3 |
08-23-2018, 08:27 PM | #4 |
You can also use Model Airplane Fuel Proof paint.
Works well on carburetors also |
08-24-2018, 12:02 AM | #5 |
You got that right about Rustoleum being a grayish black.
I don't know why it's so hard to find a true black in a spray can. |
08-24-2018, 05:28 AM | #6 |
08-24-2018, 06:23 AM | #7 |
I use VHT High Temp Engine Enamel. Available at Auto Zone or even Wal Mart. Has a good gloss and after it fully cures doesn't seem to be bothered by fuel . Chap
08-24-2018, 08:38 AM | #8 |
I was under the impression that lacquer was not bothered by gas. Anyone know about this.
08-24-2018, 08:48 AM | #9 |
I think a good true black gloss enamel paint in a spray can is at ACE Hardware. The best part is that it has a very good spray nozzle that can be turned horizontal or vertical. It is great for small parts. Note, not so good for engine pans and I agree get them powder coated. I used to work for a valve company and all the valve bodies were powder coated, powder sprayed in a booth and then oven dried. You would have to sand blast to get it off. Ed
08-24-2018, 09:57 AM | #10 |
The powder coated ones from the vendors will get gray streaks where the gas hits it.It won't wrinkle,and stays in place,but discolors.I heard a guy in my garage say to someone,whyn't you just fix your carburetor? I thought it was funny because the guy that asked the question won't park on anybodys hot top because his A drips everything.
08-24-2018, 10:18 AM | #11 |
DuPont company makes an automotive rattle can paint branded under the NASON name. Their black is excellent and I get it at an independent auto parts store here in Maine. I'm sure it is sold elsewhere. I have it on my engine pans and other A parts with no issues.
08-24-2018, 12:12 PM | #12 |
Good Morning...Just me, but I keep the area under the carburetor on the splash pan unpainted. At least it looks like it is intended to be that way...not stock...but I'm no longer stock at 71 either! Ernie in Arizona
08-25-2018, 08:45 AM | #13 | |
FYI; DuPont has not manufactured paint in over 3 years. |
08-26-2018, 11:35 AM | #14 |
Brent: You're right on the ball I see ! AXALTA coating systems.NASON Finishes , Glen Mills, PA. WWhatever the name, it is very good rattle can paint.
