Old 12-01-2021, 09:51 AM   #1
sprint29
Default Door check question
I have a 36 pickup. I was needing to know what is used in the little hole in the strap to the bracket on the cab? A little bolt was in there when I took things apart. It wasn't factory because each door didn't have the same bolt in it.
Thanks
Mark
sprint29 is offline   Reply With Quote
Old 12-01-2021, 12:05 PM   #2
nelsb01
nelsb01's Avatar
Default Re: Door check question
Not really a great picture, but it can give you an idea of what it looks like. I believe (and Mr Rogers will correct me if I am incorrect) that the door frame bracket was fastened with a split rivet. And inside the door, was a cotter pin.
nelsb01 is offline   Reply With Quote
Old 12-01-2021, 02:00 PM   #3
sprint29
Ok Thanks. I appreciate the help
Old 12-01-2021, 06:29 PM   #4
fordv8j
fordv8j's Avatar
1938 cars had a flat washer, and a rubber bumper on the strap inside the door, trucks may be the same, and a cotter pin to hold them on
fordv8j is offline   Reply With Quote
