Old 11-13-2021, 11:27 AM   #1
Uncle Jack
Uncle Jack's Avatar
Default Ford Carburetor question
I am starting a rebuild on my 8BA that has been sitting around to long and I have a vintage Edmunds dual intake I plan on using. I also have 2 pair of old ford script carburetors - one pair is marked model 8BA - 94, the other pair is marked ECW - 1 1/16. Should I use the 8BA 94s or does it matter - what is the difference ? I am also thinking I will probably go with a converted Chevy distributor. Thanks for any info.
Uncle Jack is offline   Reply With Quote
Old 11-13-2021, 11:51 AM   #2
Charlie ny
Default Re: Ford Carburetor question
Use the 94's
Charlie ny
Charlie ny is offline   Reply With Quote
Old 11-14-2021, 10:22 AM   #3
Uncle Jack
Uncle Jack's Avatar
I think i will - thanks
Old 11-14-2021, 12:03 PM   #4
scicala
scicala's Avatar
I believe the ECW carbs would be from around a '56 Ford truck 272 Y Block V8. If you're after a little more air flow, the 1 1/16"carbs would have that, but also have a V-Bead for the air cleaner mointing, and not a flat circle like the passenger car 8BA' 94's.
Sal
Old 11-14-2021, 06:37 PM   #5
Burt Lake Barn
Burt Lake Barn's Avatar
From what I’ve read, the 8BA was used in 1949 and had been considered to have better flow than previous years. That would be my choice.
Burt Lake Barn is offline   Reply With Quote
Old 11-14-2021, 06:46 PM   #6
Newc
Newc's Avatar
Just remember the power valve rating for 94's in a pair ect. Newc
Old 11-14-2021, 07:49 PM   #7
tubman
tubman's Avatar
Talk to "Charlie ny" about this. He won't steer you wrong.
Old 11-14-2021, 09:57 PM   #8
ford38v8
ford38v8's Avatar
Burt, with respect, I’d be interested in the source of your Comment on better flow. From my experience, I’ve seen nothing to support that belief.
Alan
ford38v8 is online now   Reply With Quote
Old 12-15-2021, 02:34 PM   #9
Burt Lake Barn
You know Alan, I read that somewhere in a blog that listed the different model numbers of 94’s, what years they were used, on cars or trucks etc. and it had a few comments here and there about each. As with anything, some things are based on quantitative testing and some you find are opinions. I thought they talked about an improvement made that year to the fuel spray tubes or something.
