11-30-2021, 04:43 PM | #61 | |
Re: Mounting ‘Tubman’ condenser on dome distributor
I took the coil wire off and itself alone is getting 6.2 volts which is good. When I put it back on the coil it has 2.3 like yesterday. I was thinking could this be caused by the ‘springy part’ of the coil grounding to the housing? |
11-30-2021, 06:19 PM | #62 |
The 2.3 volt reading could result from any high resistance connection/component in the circuit to the coil including connections at the resistor and ignition switch. Just this past summer, I had to replace the original resistor and ignition switch in my '34 in order to get the proper/correct voltage readings at the coil...
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 11-30-2021 at 10:25 PM. |
11-30-2021, 07:31 PM | #63 | |
I took the coil off to test this and with the coil off and wire connected I get 6.3 to the coil so it is something at the distributor throwing the volts off. |
11-30-2021, 07:42 PM | #64 |
Try and get the distributor to the position where the points are open. (No continuity to ground). Then refit the coil and check you still have your 6.3 Volts.
The lower voltage reading you are seeing may be perfectly normal if the points are closed. (not sure). Just checking - are you getting any sign of a spark at a plug, yet? Mart. |
11-30-2021, 10:21 PM | #65 | |
With the ignition switch on you should have 6 volts at the coil if the points are open and about 3.5 to 4 volts at the coil if the points are closed - The 2.3 volts you are reading is too low with the points closed. You can tell when the points are open or closed by the change in voltage as measured at the coil. With the ignition switch on, bump the starter a little bit to observe the change in voltage....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 12-01-2021 at 12:27 AM. |
12-06-2021, 05:44 PM | #66 | |
Hey everyone I have some good news and some bad news. I bought a NOS condenser to see if that would do anything and I got it in today and I now have spark. That’s the good news! The somewhat bad news is when trying to start it, it kicked over 2 times as if it wanted to start but it didn’t start all the way and I couldn’t get it to kick over again. So I have spark and it wanted to start but it wouldn’t do it again. Also I have 6.3 with points open 2.5 with points closed. |
12-07-2021, 08:32 AM | #67 | |
My concerns are on timing, I also want to make sure the tail pip is clear as it had been sitting in a garage/barn with evidence of mice. Also the low dip in the voltage when points are closed, should that be a concern? |
12-07-2021, 12:36 PM | #68 |
hi Chris, Are you sure it's still getting gas, and/or maybe it's flooded.
Also, do you have someone you can get to hold a hand over the end of the exhaust pipe, to see if some air is coming out there, when you turn it over ? The odds of it being plugged solid is very slim. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
12-07-2021, 07:14 PM | #69 | |
It is possible it’s flooded but I only pumped the pedal 4 or 5 times so if it is what would I do? And there is air coming out I noticed it has been blowing stuff out of the exhaust pipe like a few chewed pecans. |
12-07-2021, 07:23 PM | #70 |
Pull some spark plugs and see if the electrodes are wet or not.
If the plugs are pretty dry looking, then maybe spray a little starting fluid into the carb and see if it will try to start. .
12-09-2021, 04:37 PM | #71 | |
Check this video out. Progress from the other video. This is trying to start it with half of choke and a good squirt of starting fluid. What do y’all think? https://youtube.com/shorts/S3mq0LW27AM?feature=share |
12-09-2021, 04:51 PM | #72 |
Have you done a compression check? What are the engines compression values? Check to see if the engine has decent compression....
12-09-2021, 04:54 PM | #73 |
12-09-2021, 06:18 PM | #74 | |
OR, if you don't want to do the compression test, you can remove the spark plugs and squirt a little motor oil into each cylinder. Replace the spark plugs and then try to start the engine.... Four-Stroke = Intake - Compression - Combustion - Exhaust
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 12-09-2021 at 07:44 PM. |
12-15-2021, 03:23 PM | #75 | |
Still fighting it, shot of oil in the spark plug holes didn’t do the trick. Plan to rent a compression tester from advance auto. I was thinking about switching to 12 volt so I could switch to a electric distributor. This would prevent from a future battle with the distributor and spark. What are y’all’s take on 12volt? Thank you to all for the help! |
12-15-2021, 05:44 PM | #76 |
Contact the people in the Early Ford V8 Club nearest you and try to get some in-person help with your starting problem....
NC Piedmont (RG# 52) 920 Elderberry Lane Clover, NC 60196 Contact: Michael Palmer EM: [email protected] PH: 803-831-9413 NC Central Carolina (RG# 16) 382 JL Temple Road Lexington, NC 27295 Contact: Jay Temple EM: [email protected] PH: 336-956-4438 NC Blue Ridge V-8 (RG# 146) 246 Lakewood Drive Wilkesboro, NC 28697 Contact: James Cashman EM: [email protected] PH: 336-921-3729
12-15-2021, 07:15 PM | #77 | |
Chris, when doing a compression test, use a long screw driver or something to hold the bottom throttle plate open on the carb. You want the cylinders to be able to suck a lot of air into each cylinder so you get an accurate compression reading. .
12-15-2021, 07:30 PM | #78 | |
Thank you for this! I knew of the club but had no idea I had people this close to me in the club. I will try and contact some tomorrow! |
12-16-2021, 01:25 AM | #79 |
In all the posts so far you have not convinced me that you have tested at one spark plug for a good spark. And now you are talking about 12 volts and electronic distributor. Dont even think about it and just fix the excellent 6 volt ignition that the car came with. Forget about testing voltages and just test to see if you are getting spark at the plug leads. By the way your engine is cranking over on the starter at a nice speed as it should and it is not too fast as has been mentioned earlier. Pull one spark plug lead off the spark plug and hold it about 1/4"inch away from a head stud nut and crank the engine on the starter. You should get a red/blue TIMED spark meaning that there is some time lag between sparks. Your assumption that the voltage readings you are measuring at the coil are not OK may not be correct. Others have mentioned that these voltage readings can vary quite a bit, so just forget about that at the moment because you are becoming sidetracked with it. Just test that spark as I have outlined and report back. Regards, Kevin.
12-16-2021, 07:16 AM | #80 |
Why do you have two wires coming out of your coil?
Thread Tools | |
Display Modes | |
