11-13-2021, 11:27 AM | #1 |
Ford Carburetor question
I am starting a rebuild on my 8BA that has been sitting around to long and I have a vintage Edmunds dual intake I plan on using. I also have 2 pair of old ford script carburetors - one pair is marked model 8BA - 94, the other pair is marked ECW - 1 1/16. Should I use the 8BA 94s or does it matter - what is the difference ? I am also thinking I will probably go with a converted Chevy distributor. Thanks for any info.
11-13-2021, 11:51 AM | #2 |
Re: Ford Carburetor question
Use the 94's
Charlie ny |
11-14-2021, 10:22 AM | #3 |
I think i will - thanks
11-14-2021, 12:03 PM | #4 |
I believe the ECW carbs would be from around a '56 Ford truck 272 Y Block V8. If you're after a little more air flow, the 1 1/16"carbs would have that, but also have a V-Bead for the air cleaner mointing, and not a flat circle like the passenger car 8BA' 94's.
Sal |
11-14-2021, 06:37 PM | #5 |
From what I’ve read, the 8BA was used in 1949 and had been considered to have better flow than previous years. That would be my choice.
11-14-2021, 06:46 PM | #6 |
11-14-2021, 07:49 PM | #7 |
Talk to "Charlie ny" about this. He won't steer you wrong.
11-14-2021, 09:57 PM | #8 |
Burt, with respect, I’d be interested in the source of your Comment on better flow. From my experience, I’ve seen nothing to support that belief.
Alan |
12-15-2021, 02:34 PM | #9 |
You know Alan, I read that somewhere in a blog that listed the different model numbers of 94’s, what years they were used, on cars or trucks etc. and it had a few comments here and there about each. As with anything, some things are based on quantitative testing and some you find are opinions. I thought they talked about an improvement made that year to the fuel spray tubes or something.
