08-26-2021, 07:04 PM | #1 |
What year is this truck?
I ran across this truck in the woods in Stehekin, WA. You can only get there by boat. The engine is gone. Does the steering wheel give it away? Is that a spark advance lever? Looking for what you think. The "W" on the firewall is the same as a '33 (I think), but what about the steering wheel?
08-26-2021, 07:16 PM | #2 |
Re: What year is this truck?
Mystery Ford Truck in Stehekin, WA. |
08-26-2021, 07:19 PM | #3 |
'35 - '36.......I'm headed there right now with a fresh battery and starter fluid !
Charlie ny |
08-26-2021, 07:27 PM | #4 |
Too bad. Look at the drivers side fender; it appears that wasn't bad when it was left there.
Why do they have to shoot holes in everything? |
08-26-2021, 07:30 PM | #5 |
I think the parking brake handle may still be good. Interesting that the gas tank is still there.
Red |
08-26-2021, 07:33 PM | #6 |
08-26-2021, 10:50 PM | #7 |
Hard to tell from the photo but does it have parallel rear leaf springs? If so, a 3/4 ton or larger?
08-26-2021, 11:37 PM | #8 |
It was a logging operation and it was left to be cannibalized.
08-26-2021, 11:59 PM | #9 |
the fire wall is desirable to the fools that put modern motors in the model 40's, as it fits rite in, but has a bit of a set back for more clearance.
08-27-2021, 06:29 AM | #10 |
51504bat...I do not believe that Ford made a 3/4 ton until 38. The pictures appear to show the remains of a 1 1/2 ton. The headlight buckets on it appear to have been changed out at some point after seal beams became available.
08-27-2021, 06:59 AM | #11 |
My guess would be '35 as I don't see the reinforcement "X" stamped in the side of the cowl. Hard to tell in the pictures.
Stay Safe! Pat |
08-27-2021, 03:25 PM | #12 |
My guess is '36 because of the "hand-holds" in the doors to grab the doors when closing. Or maybe a '35 with '36 doors.
08-27-2021, 03:55 PM | #13 | |
Hi Everyone. I hope this doesn't muddy things in the discussion of commercial/truck ID's, but in this thread about '35 Roadster doors (https://www.fordbarn.com/forum/showthread.php?t=302899) DavidG added to the information with:
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
08-27-2021, 06:39 PM | #14 |
I'm guess it's a '35 Model 51, short WB. These are pictures of my, unmolested '35. It looks the same to me. If you look lose you can see the "X" , same s mine and if you look even closer, you might make out the lower W stamping below the upper one. Look more and you can see the patent plate in the middle of the X.
I also took one of the door grip and molding.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline Last edited by frnkeore; 08-27-2021 at 06:44 PM. |
08-27-2021, 07:21 PM | #15 |
Yes a '35 or a '36 and dang somebody already ran off with the rear fenders
08-27-2021, 07:44 PM | #16 |
All that will buff out.
08-27-2021, 08:11 PM | #17 | |
Bill |
08-28-2021, 08:51 AM | #18 |
And of course; It was running when parked!
08-28-2021, 08:57 AM | #19 |
its a 1935 Ford and its a big truck , it has the big truck steering wheal
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
08-28-2021, 11:01 AM | #20 |
1936. There is a difference between 1935 and 1936 where the windshield post meets the cowl.
