Old 05-04-2011, 06:32 AM   #1
Fibber Mcgee
Fibber Mcgee's Avatar
Default F1 vin
Does any one know if there is a way to tell the assembly plant by the serial number on a 49 F1?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 05-04-2011, 07:27 AM   #2
mtflat
mtflat's Avatar
Default Re: F1 vin
Only if they happened to stamp it at the end of the line. Most plants didn't. Look for two capital letters.
You'll have better luck if you find a stamped assembly code on the firewall. Look for something like 7RHI2L6025 (my 48F1). Post it here or shoot me an email and I'll be glad to sort thru it with you. mtflat@hotmail dot com
mtflat is offline   Reply With Quote
Old 05-04-2011, 08:08 AM   #3
Fibber Mcgee
Default Re: F1 vin
Where would I look on the firewall?
Old 05-04-2011, 12:20 PM   #4
2ndgeer
2ndgeer's Avatar
Default Re: F1 vin
There is an extensive discussion of F1 serial numbers and codes on the Ford Trucks website including where to find the assembly plant codes...
http://www.ford-trucks.com/forums/42...ut-off-47.html
2ndgeer is offline   Reply With Quote
Old 05-04-2011, 05:49 PM   #5
mtflat
mtflat's Avatar
Default Re: F1 vin
They often used letters 3/8" to 1/2" tall and can be anywhere on the firewall, but often located near the center or slightly toward the driver's side.
Can be found above the cowl seam, but usually below it.
Stampings are normally faint depending on how many layers of paint are there.
Some trucks didn't get one at all. Plants showed a lot of imagination - this wasn't standardized - so you'll see most anything.
If you see what appears to be a random series of numbers/letters, copy them down. We can probably sort it out.
Old 05-04-2011, 06:44 PM   #6
ct50f1
ct50f1's Avatar
Default Re: F1 vin
Should look something like this.
ct50f1 is offline   Reply With Quote
Old 05-05-2011, 06:30 AM   #7
Fibber Mcgee
Default Re: F1 vin
There are some faint marks on the pass side firewall just below the seem that look like 7 H P 0 3 is that anything?
Old 05-05-2011, 07:54 AM   #8
mtflat
mtflat's Avatar
Default Re: F1 vin
7 is the code for meadow green
HP is for Highland Park, MI
03 is in the date area
I have very little data for HP firewall stampings - only one other truck.
Old 05-05-2011, 08:08 AM   #9
Fibber Mcgee
Default Re: F1 vin
Thanks alot that must be right because the trucks original color was green.Thats alot more than I knew about my truck.
Old 05-05-2011, 08:18 AM   #10
mtflat
mtflat's Avatar
Default Re: F1 vin
You're welcome. A couple of us have been collecting serial numbers for the past 10 years trying to re-construct some of the info lost in '67 when Ford destroyed the old records. We have collected hundreds of vin/serial numbers from 48-50 trucks that have helped other guys know what they have.
Since info is so scarce on HP trucks it would be great to include your vin number in the mix if you don't mind. PM or email if you don't want to post it on the forum.
The 03 in the firewall stamp would be the day. There should be a letter for the month following the number.
Old 05-06-2011, 05:59 AM   #11
Fibber Mcgee
Default Re: F1 vin
I sent you the info and I looked on the firewall,but I dont see any other letters.
