Old 11-02-2017, 05:46 PM   #1
Dennis Mielke
Default Hydraulic brakes
Just acquired a 34 roadster that installed hydraulic brakes several years ago. On inspecting the brakes I found that the line to the left rear brake has a hole in it. Can anyone recommend a shop in or near Orange County, CA. That installs or repairs hydraulic brakes in early fords besides The Early Ford V8 Garage which is booked up for the foreseeable future. I'm located in Costa Mesa.
Thanks for any help.
Dennis Mielke is offline   Reply With Quote
Old 11-02-2017, 06:27 PM   #2
corvette8n
corvette8n's Avatar
Default Re: Hydraulic brakes
You should be able measure the line and get a replacement.
Old 11-02-2017, 06:46 PM   #3
JSeery
JSeery's Avatar
Nothing really special about swapping out a brake line. Any shop that is willing to work on it should be able to fix it with no issues.
Old 11-02-2017, 08:07 PM   #4
48fordnut
48fordnut's Avatar
measure line ,determine the size ,go to auto supply house get line .Come back to shop take line off, bend new line to old one ,install, bleed brakes. Enjoy.
48fordnut is offline   Reply With Quote
Old 11-02-2017, 08:34 PM   #5
Zephyr Q
Zephyr Q's Avatar
If you're looking for a shop, I can't say enough good things about C.H. Topping in Long Beach. I had them change the master cylinder and split the system on my Lincoln a few months back. Very knowledgable on vintage and customs.
Zephyr Q is offline   Reply With Quote
Old 11-02-2017, 10:00 PM   #6
Frank Miller
Frank Miller's Avatar
Does the pedal go to the floor? if not then you do not have a hole in it. It just seems odd a steel line getting a hole on what I presume to be a restored running car. If the steel line needs to be replaced, do you feel up to learning some stuff? It should not be hard to remove and going to the parts store to find a replacement is not difficult. Then you need to bend it carefully to match the old one and carefully start the fittings making sure they are square and screw in easily a couple of turns before putting a wrench to them. If you're not inclined to swear, you might want to practice up a bit. I find the right words tends to move the job along.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 11-04-2017, 01:44 PM   #7
supereal
supereal's Avatar
Out here in the midwest the slush and salt on the roads eats brake lines. A good shop can duplicate the bad line from stock to fit the application. Making the double flares and getting the bends correct and without kinking requires experience. This is vital to older vehicles with single circuit brakes for safety's sake.
supereal is offline   Reply With Quote
Old 11-04-2017, 06:48 PM   #8
Mart
Mart's Avatar
Do it yourself. get a sense of achievement. People on this forum will give you all the guidance you need.
As mentioned above..
Take line off, measure the length as if it was straight. Go to napa. Buy the closest line (longer if necessary). fit new line. Bleed brakes.
Piece of cake.
You don't need a shop to do this.
There may be a barner nearby that can lend a hand.
Mart.
Mart is online now   Reply With Quote
