09-03-2017, 05:48 PM | #21 | |
Re: 37 Engine?
Charlie Stephens |
09-03-2017, 07:40 PM | #22 |
Re: 37 Engine?
I have a correct engine for your car. Email me
[email protected] if you want to pursue the matter. John |
09-03-2017, 08:09 PM | #23 |
Re: 37 Engine?
Here's what the correct engine looks like....
09-04-2017, 08:33 AM | #24 |
Re: 37 Engine?
While the Dagenham, UK engines are technically correct, the cylinder head gives away the British origin. The US engines would have had very little cast marking on the cylinder head. The first 37 (77 prefix) were aluminum 77-6050 then later the 77-6050-A cast iron ones were produced. The Commonwealth version were 77E prefix and many had a dim Ford USA casting mark while the firing order marks were crisp in their raised relief. These are good replacements but are not authentic for USA production. These engines were manufactured for a long time in UK and Canada since they were in production for war time track vehicles like the Universal Carrier. The UK had a policy of selling surplus war equipment back to the manufacturer after secession of hostilities so they stayed around for a good bit after the war.
09-04-2017, 09:57 AM | #25 |
Re: 37 Engine?
09-04-2017, 01:17 PM | #26 |
Re: 37 Engine?
The picture is again terrible and he hasn't sent me anymore pictures, but this looks a lot more like a 37 engine to me. Where can one find the engine number on these engines? In case it is a 37 engine, I'd like to try and determine if it could have been original to the 37. Thanks for your comments |
09-04-2017, 01:36 PM | #27 |
Re: 37 Engine?
Count the head studs/nuts. If it's a '37 it will only have 21 studs....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 09-04-2017 at 02:46 PM. |
09-04-2017, 01:55 PM | #28 |
Re: 37 Engine?
Here is my 1937 engine that was original to the car -- has later model generator and voltage regulator.
09-04-2017, 01:57 PM | #29 | |
Re: 37 Engine?
A '36 engine does have 21 studs per cylinder head like a '37, but the '36 cylinder heads each have an integral water pump mounted at the front, where-as the '37 and '38 engines have the water pumps bolted into the front face of the block. DD |
09-05-2017, 08:35 AM | #30 |
Re: 37 Engine?
Actually, the '37 engines are easier to find than the earlier 21 stud engines. The '37 style block was used for replacement engines for the '32 - '36 style. There were block-off plates used to cover the water pump openings. The heads used were the '36 style which had the pumps in the heads, but used dome pistons. The '37 blocks become available when folks restore their '32 - '36 cars back to original.
