04-19-2016, 08:25 AM | #1 |
An Old Guy, A Comb, and "A" Comment
I had my 1929 Roadster parked at a restaurant Saturday morning. This older man comes over and starts talking about "the old days," cars and stuff.
He asks me if I think the motor is any good and is it tuned properly? I said I thought so. He asks if he can check. I start the car, let it warm up and he removes a plastic comb from his pocket. He then individually removes one spark plug wire at a time. As he does this the car keeps running, obviously a little slower with each one removed until it is running on one cylinder. With that he congratulates me. He declares the engine good and properly tuned. He says that's the way they did it "back then". What do you think? |
04-19-2016, 08:46 AM | #2 |
Re: An Old Guy, A Comb, and "A" Comment
That's how Tex does it also. Must be some thing in the corn whiskey.
https://www.youtube.com/watch?v=qudp...&nohtml5=False |
04-19-2016, 08:54 AM | #3 |
You shouldn't leave the spark with no path to ground. It will try to jump inside the coil, along the coil tower, through the rotor to the shaft, or crossfire inside the distributor body.
You are much better off to ground out each plug, even if this involves having someone holding their fingers on the plugs. |
04-19-2016, 08:55 AM | #4 |
A real man would have removed the wires with his bare hands.
That would not be me! |
04-19-2016, 09:27 AM | #5 | |
04-19-2016, 09:42 AM | #6 |
Hmmm .......... Wonder how he checks his wife to see if she is still still good and tuned properly ????? |
04-19-2016, 09:47 AM | #7 |
FWIW, I knew an old fellow, back in the '50's, who would stall a Model A by putting his thumbs on the cylinder head and his fingers on the spark plug wires. I'm too chicken to try it.
04-19-2016, 11:00 AM | #8 |
ah, the old comb trick...............
did he use brill cream before the start? |
04-19-2016, 11:07 AM | #9 |
What's a comb???
04-19-2016, 11:29 AM | #10 |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Ask Cookie!!! He might have one to lend you!!!
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
04-19-2016, 11:35 AM | #11 | |
It was fun to watch the expression on the faces of the customers. |
04-19-2016, 12:16 PM | #12 |
Chief could KILL a 4 cyl engine by shorting the plugs out, with his fingers!! BUT, he couldn't do it on an electronic ignition system---ZAAAAP!
Bill W.
04-19-2016, 12:18 PM | #13 | |
What was the pattern? Front to back or back to front?
04-19-2016, 01:21 PM | #14 |
Great, now your Model A has that Old Codgers "Cooties"!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
04-19-2016, 03:08 PM | #15 |
04-21-2016, 10:14 AM | #16 |
Forerunner of the modern day pacemaker.
04-21-2016, 10:35 AM | #17 |
04-21-2016, 08:12 PM | #18 |
A grounded test light works pretty good, on cars with insulated plug wires you can slip the point between the wire and boot to contact the top of the plug. No shock, no harm to the ignition system.
04-22-2016, 11:04 AM | #19 |
I don't follow what you're saying. Are you saying to use a 6 or 12 volt test light to check for spark at the plug. How does that work?
04-22-2016, 05:53 PM | #20 |
You can use either. The test light will not light up, it will provide a safe path to ground for the spark. It is not for checking for spark, it is for seeing if that cylinder is contributing. There should be a noticeable drop in RPM when "shorting" a wire while running.
