Old 09-30-2021, 04:58 PM   #1
Minn-Tex Lee
Minn-Tex Lee's Avatar
Default coolant level concern
I am using a Brassworks radiator so I can't really tell when the tubes are covered, so I fill the radiator to the top of the neck. If I run the engine in the parking lot without going anywhere, even for a half hour, the fluid level does not change.When I take it out for a 8 mile drive I fill it up again and find it has thrown out about 2 quarts.
Does this sound normal or do you think there is a problem?
Lee
Minn-Tex Lee is offline   Reply With Quote
Old 09-30-2021, 06:53 PM   #2
Dean Lemoine
Dean Lemoine's Avatar
Default Re: coolant level concern
I had the same experience with a “new to me car”and new Brassworks radiator. It dumped water through the overflow until it found it’s level. The level in mine is below the baffle. I made a sight tube out of clear tubing to know exactly where the water level is. It settled at about an inch and half above the tubes.
Dean Lemoine is offline   Reply With Quote
Old 09-30-2021, 07:31 PM   #3
Big hammer
Lee
One problem I see if your using anti-freeze it's ending up on the ground. I over fill the radiator so I see the coolant, I then use the petcock and drain the coolant just below the baffle. If you wonder what the level is add so you can see then drain just under the baffle.
get a bigger hammer tap done
Old 09-30-2021, 07:32 PM   #4
Ivan in southeast va.
Ivan in southeast va.'s Avatar
You are over filling the radiator. Let it find its own level. Two quarts does seem excessive but you are probably fine.
Ivan in southeast va. is offline   Reply With Quote
Old 09-30-2021, 11:17 PM   #5
Ruth
That's a good way to check it when cold. I usually check mine when it is hot. When hot my level is just above the baffle.
Ruth
Old 10-01-2021, 08:47 AM   #6
Patrick L.
Patrick L.'s Avatar
Not familiar with that radiator, but, always dropping 2 qts I would think is a problem.
Old 10-01-2021, 10:11 AM   #7
Ruth
Does it loose any more than the 2 qts and more importantly does it run hot/over heat at any time?
Ruth
Old 10-01-2021, 11:11 AM   #8
goodcar
Too full will cause the coolant to be siphoned out through the overflow tube.
goodcar is offline   Reply With Quote
Old 10-01-2021, 03:13 PM   #9
Minn-Tex Lee
I built a site tube so now I can keep an eye on the level. Now I can see if it will finally level out at some point.
Thanks for all of those good ideas.
Lee
Old 10-01-2021, 03:33 PM   #10
Mister Moose
Mister Moose's Avatar
Lee
Could both of you please post a photo of your sight tube showing where it is and how you installed it? I have the same difficulty telling how much coolant is in the radiator.
Mister Moose is offline   Reply With Quote
Old 10-01-2021, 07:13 PM   #11
Dean Lemoine
I ran the tubing between the radiator and the shell. I put an isolation valve in case the tube should leak. It’s been there for about a year with no problems. I open the valve to check the level then close it when I’m finished
File Type: jpg 03FEFD79-B3CD-4C8B-B685-4717B8D677B5.jpg (37.2 KB, 55 views)
