Old 06-25-2017, 12:41 PM   #1
mcharley40
Default 1940 Ford Tonner production numbers
Hello Everyone !! New to the forum this past year, just been reading great info. I own and have owned several old rides, both with four wheels and two. Travel a lot for work so I get to hit many swap meets and events all over the country.
One of the old trucks I own is a 1940 ford Tonner. my father in law has some old old trucks as well mentioned to me a while back that Ford only made about 2500
Ford 1 ton pickups in 1940. I have done a thread search but have not found anything confirming this. Can anyone set me in the right direction ?? Again thanks for a great site
mcharley40 is offline   Reply With Quote
Old 06-25-2017, 01:29 PM   #2
mcharley40
Default Re: 1940 Ford Tonner production numbers
Could my father inlaw's estimate forgotten a zero?? I have seen a 122" wheel base trucks over the years so 2500 seems short, I saw in a thread source 1/2 ton numbers but could find anything for 1 ton.
Old 06-25-2017, 02:33 PM   #3
alanwoodieman
what wheels do you have 16" or 17"? 3/4 ton trucks had 16", 1 ton had 17" flat base rims/tires. I have a 1941 3/4 ton stake bed truck and have also been told there was about 2200 of them made
alanwoodieman is offline   Reply With Quote
Old 06-25-2017, 02:48 PM   #4
mcharley40
Hello, I have the 17" wheels that came with the truck, but I also picked up a set of 16". Lots of tire options. I have been talking with another guy who might be parting with a set of 20" wheels. If he decides to sell them I am sure I will buy them even if I don't run them. My truck has a serial number BB and end 9Y. Where did you get the production numbers information ??
Old 06-25-2017, 03:55 PM   #5
GB SISSON
GB SISSON's Avatar
Are you sure the 16" and 17" wheels interchange? 17's are 5 on 6 7/8" pattern with 3/4" studs. The 16's might be more like the wide 5 pattern, but I have never had one and so I'm just thinking out loud. I have a collection of the tonners here. As far as your original question, I just remember there were less tonners built than the 1/2 tons. Still a lot of tonners on the market because most people wanted the 1/2 tons to restore and used them up. Me, I never had a use for a half ton. Couldn't haul plywood and I own a cabinetshop....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 06-25-2017, 03:56 PM   #6
alanwoodieman
Ford Trucks since 1905 by James K. Wagner has a lot of info, also the V8 club has some info and Loren Sorenson's book on commercial Fords is also good
Old 06-25-2017, 06:39 PM   #7
alanwoodieman
are you sure BB is at the beginning, 18- for 85 hp V8, 99- for 95 hp V8, BB usually denotes a 4 cylinder B engine. Y is one ton, D is 3/4 ton
Old 06-25-2017, 08:07 PM   #8
mcharley40
Hello, Yes it is most deffinately 18-BB and ends 9Y. so is my father inlaw's ton an a half. BB is big truck single B is four cylinder. Both of these trucks where bought new localy here in western Colorado. I know the history of mine and the family that bought it.
Old 06-25-2017, 08:24 PM   #9
mcharley40
I have a photo of my serial number in my profile
Old 06-25-2017, 08:49 PM   #10
JSeery
JSeery's Avatar
Think that confuses things a little, it is BB18- not 18-BB, correct?
Old 06-25-2017, 08:59 PM   #11
mcharley40
Yeah BB18 - I wrote it wrong earlier,
Old 06-25-2017, 09:00 PM   #12
Kube
Kube's Avatar
The "BB", at least in 1940, indicated a four speed truck regardless of whether it was a half, 3/4 or one ton chassis.
Old 06-25-2017, 09:04 PM   #13
Kube
Kube's Avatar
In all of my research, I came upon nothing that broke out the one ton pickup trucks. How anyone came up with 2200 I have no clue. I would readily admit the information may be in the Ford Research Center but I never saw a hint of it.
