01-14-2017, 04:32 PM | #1 |
pickup rear window
31 pickup..... does the rear window on the 30/31 pickup use a gasket or seal of some kind. i got a new frame from mikes and will be ordering the glass soon. i can't see any listed in the catalog, but surely there should be one.
01-14-2017, 04:56 PM | #2 |
Re: pickup rear window
01-14-2017, 06:07 PM | #3 |
thanks! that looks like what i need./ don't know why i didn't see it in either theirs or mikes catalog. getting older and stupider everyday.
01-14-2017, 08:42 PM | #4 |
The recommended super glue trick works well...im not 110% sure about the pickups but on the Tudors the seam meets on the top center
01-14-2017, 09:15 PM | #5 |
The rubber gasket comes as a six foot piece. You stretch it tight around the glass and then cut it to size. Remove the rubber and super glue the ends. Let it cure for 24 hours or more and put back on the glass.
You can position the joint any where you desire. The hard part is getting the washer and nut on the 18 screws behind the frame. I finally bent a 3/8" open end wrench to almost ninety degrees and then super glued a thin magnet to back of the open end. That held the nut and washer on the back side of the frame while I started the screw. A little sticky on the washer helps hold it against the nut Last edited by GPierce; 01-14-2017 at 09:28 PM. |
01-14-2017, 09:21 PM | #6 | |
01-14-2017, 09:26 PM | #7 |
01-14-2017, 09:30 PM | #8 |
01-14-2017, 09:57 PM | #9 |
JS book page 10-2 revision 2016 the seam on all stationary rear glass is center top...
01-14-2017, 10:08 PM | #10 |
01-14-2017, 10:40 PM | #11 |
01-15-2017, 03:38 PM | #12 |
more good info...thanks guys
01-15-2017, 04:02 PM | #13 |
For those nuts on the pickup I have a very simple to make tool to hold them if I can find it I will make a drawing if anyone is interested PM me at [email protected] I don't get on the forums much any more just had a few questions today and posted.
Building Horse Power -- |
