Old 03-17-2023, 10:37 PM   #1
Stephen Pellegrino
Stephen Pellegrino's Avatar
Default Need 1958 Ford Speedometer Help
I have a 1958 Ford Custom 300 w/ a six & automatic. The speedometer reads about 5-15 MPH slow, depending on speed (at faster speeds it's more accurate). Also the needle sticks at 0 until you're going about 30 MPH.
When I got the car it had no speedometer driven gear in the transmission. I bought one from Echler's (described as correct for '57 & up Fordomatic, but I don't think it's right). I have a 3.56 rear axle ratio, and according to the 1958 Ford shop manual, I should have a gear with 22 teeth. Can't find one. Gear photo shown is from an eBay auction I missed out on. Anyone have any suggestions?
Stephen Pellegrino is offline   Reply With Quote
Old 03-17-2023, 11:15 PM   #2
miker98038
miker98038's Avatar
Default Re: Need 1958 Ford Speedometer Help
Since the speedo is sticking, and the error is variable, I’d look at the speedo head first. I’m not familiar with the 58’s, but other speedos have some lube provisions or need cleaning. Hopefully someone will chime in. Much better than not working at all.
As an aside, does the mileage work and appear accurate?
Nice ride. One of Fords best in my book.
miker98038 is offline   Reply With Quote
Old 03-18-2023, 04:28 AM   #3
mercman from oz
mercman from oz's Avatar
1958 Ford Custom 300 Fordor Sedan - Stephen Pellegrino
Old 03-18-2023, 08:21 AM   #4
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Need 1958 Ford Speedometer Help
Gear photo shown is from an eBay auction.
That gear is correct - 1957/58 FORD F/M 3.56 RATIO 7.50 X 14
KULTULZ is offline   Reply With Quote
Old 03-18-2023, 02:28 PM   #5
paul2748
paul2748's Avatar
I suggest you resolve the speedo problem before playing around with new driven gears. That could be the source of your problem.
Do you have any idea of the # of teeth in the gear you have ?
This company repairs speedos - Williamson's Instruments in Arkansas
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-18-2023, 05:07 PM   #6
dmsfrr
dmsfrr's Avatar
Check the accuracy of the odometer before changing the driven gear.
Being gear driven the odometer will be more accurate than a speedometer needle driven with magnets & springs. If the odometer indicates very near correctly, a good cleaning, adjustment or light lubrication to the speedometer parts you have may be all it needs.
Old 03-20-2023, 01:04 PM   #7
rotorwrench
rotorwrench's Avatar
The magnet rotor and drag cup bearings do need some attention after many years of neglect. If it has a proper tooth count driven gear, it should be close but worn or stiff parts can and do affect things depending on condition. The drag cup is connected to the speedometer needle and it relies on the rotating magnet to draw it into correct position.
Old 03-21-2023, 10:53 AM   #8
1930artdeco
1930artdeco's Avatar
I just had my speedo restored by a guy in Colorado and he did a good job on the whole cluster. The only issue is that the needle got bent just enough that it sticks at 30 mph when sitting still. When I get done wiring I am going to take it out and he will walk me through unbending it. I was happy though with his work.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-21-2023, 11:21 AM   #9
51504bat
51504bat's Avatar
Mike
Could be Rusty at Speedometer Service. He repaired the Stewart Warner speedo for my '39 p/u. Also sold me a cable for my '54 Ranch Wagon with an AOD. Good guy to deal with.
Speedometer, Generator And Alternator Repair In Colorado Springs (speedoservice.com)
Old 03-21-2023, 12:40 PM   #10
1930artdeco
Yep that is him. I called him about mine and he said he would walk me through it or I could send it back to him. Soo far very happy with his service and he tested my fuel/temp gauges as well.
1957 Country Sedan
Old 03-21-2023, 01:45 PM   #11
papanick
yes the bushing get gum and will not let it work right. It needs to be cleaned and serviced. papanick
papanick is offline   Reply With Quote
Old 03-31-2023, 01:18 PM   #12
Stephen Pellegrino
Thanks to all for your responses! BTW, it turns out that the fewer teeth the speedometer driven gear has, the higher the speedometer reads!
So here's what I did: I wanted to avoid taking the dash apart, so I tried switching out the speedometer driven gear at the trans (attached to end of cable). First I tried a 17 tooth gear, and then the speedo didn't work at all! So then put in an 18, and that made a noticeable improvement. The reading is still slow at 0-15 MPH, about right at 20-45, and a little high at 50-65. Not perfect, but better than it was before. I would say going from 19 teeth to 18 increased the reading about 5-7 MPH average.
I like the fact that this is a responsive board, and that so many people replied to my post!
Here are two more pictures, and a link to a web article featuring my '58 and a '57 Ford:
https://www.curbsideclassic.com/blog...-the-late-50s/
Old 03-31-2023, 01:21 PM   #13
Stephen Pellegrino
The gear I had in there was 19 teeth.
Old 04-08-2023, 01:21 PM   #14
HOTRODPRIMER
HOTRODPRIMER's Avatar
You might try and send Rusty over on the hamb a conversation, he is the resident guru on speedometers. HRP
http://www.speedoservice.com
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
