Old 07-05-2020, 07:43 AM   #1
Tim Ayers
Default Rough measurement to start with "toe" on a '32 front end
I'll cleaned, rebuilt and painted my tie rod and drag link. While putting it back together, what is a good rough measurement for setting toe before the car gets aligned?
I'll be driving it around to sort out before it gets to the alignment shop.
Thanks, all
Old 07-05-2020, 08:23 AM   #2
Mart
Mart's Avatar
Default Re: Rough measurement to start with "toe" on a '32 front end
Between 1/16" and 1/8".
That'll get you down the road.
Old 07-05-2020, 08:28 AM   #3
DavidG
DavidG's Avatar
Per page 32 of the July, 1932 Service Bulletin, the toe-in should be 1/32" to 3/32".
Old 07-05-2020, 08:38 AM   #4
Mart
Mart's Avatar
Thanks David, I was just guessing.
Old 07-05-2020, 09:12 AM   #5
Tim Ayers
Thank you.
Old 07-05-2020, 09:39 AM   #6
KGS
KGS's Avatar
Tim, Are going to use bias ply or radial tires?
KGS is offline   Reply With Quote
Old 07-05-2020, 10:08 AM   #7
Tim Ayers
Bias ply
Old 07-05-2020, 12:27 PM   #8
Kube
Kube's Avatar
I tend to set my "drivers" at 1/8". Yeah 1/32" more than the maximum specified. Makes the car noticeably easier to steer. Also, the front wheels tend to go back to "straight" easier and stay "straight" as well.
I suppose the tires will wear a tad quicker with a 1/8" toe, but in reality, they will rot before wearing out.
Old 07-05-2020, 01:23 PM   #9
Mart
Mart's Avatar
Do you mean 1/4" Kube, or 1/8"? That'd be 1/32 over max spec?????????
Old 07-05-2020, 01:28 PM   #10
DavidG
DavidG's Avatar
No doubt a typo, but 1/4" is 5/32" more than 3/32".
Old 07-05-2020, 02:53 PM   #11
Kube
Kube's Avatar
Sorry, major brain fart.
1/8"
Old 07-06-2020, 05:23 AM   #12
PeteVS
PeteVS's Avatar
I've set toe in early on when putting a front end together. Before putting the backing plates on the spindles, I bolt a pair of angle irons onto the spindle surfaces that the backing plates mount to. Their length approximates the OD of the front tires. Makes it very easy to set the toe in with a tape measure.
Old 07-06-2020, 06:45 AM   #13
Tim Ayers
Ah, great idea. I can still do that. Thanks for the tip!
Old 07-06-2020, 09:52 AM   #14
rotorwrench
rotorwrench's Avatar
The old Ford axles are a lot more flexible than a lot of folks might think. They will flex back a bit with the pressure of the roadway. It depends on how fast a person normally drives and the condition of the roadway. The type of tire carcass may have a small affect but I haven't heard of too many folks adjusting their straight axle front ends a lot for a change over to radial type tires.
Old 07-06-2020, 10:38 AM   #15
earlyride
earlyride's Avatar
When you set up toe in/toe out it should be done with the wheels on the ground. As Rotowrench states axles flex. Just the weight of the car will move your setting considerably. I measure my toe in/out half way up the center of the tire and compare front to rear, using a gauge made up to clear the frame of the car.
earlyride is offline   Reply With Quote
Old 07-06-2020, 06:26 PM   #16
rotorwrench
Those spring gauges are relatively easy to use and have little chains to get the floor distance the same from front to rear & side to side. They really don't cost much either.
