Old 04-23-2021, 02:59 PM   #1
Bryan Thompson
Default Internal engine paint
I just cleaned up an oil pump, the only debris on the screen was flakes of paint from inside the block and/or valve chamber.
What is the reason some people paint the inside of an engine?
Bryan Thompson is offline   Reply With Quote
Old 04-23-2021, 04:12 PM   #2
KR500
KR500's Avatar
Default Re: Internal engine paint
They generally coat the interior of block with Glyptol. It seals the pores of the cast iron and the oil remains cleaner.
KR500 is offline   Reply With Quote
Old 04-23-2021, 05:10 PM   #3
J Franklin
J Franklin's Avatar
I think you ran into a poor backyard job some farmer did years ago.
Old 04-23-2021, 05:33 PM   #4
Gene F
Gene F's Avatar
I worked for a professional drag racer when I was a kid. He raced Hemi superstockers. Inside of engine block was painted with EPOXY paint, to let the oil slide off and return to the pan a little faster.
Gene F is offline   Reply With Quote
Old 04-23-2021, 09:01 PM   #5
HD Rider
What he said.
They quit doing this because paint started peeling and clogging the pickup screen. I have not seen it done in the last 20 years.
HD Rider is offline   Reply With Quote
Old 04-23-2021, 09:04 PM   #6
Jack Shaft
Ford grey iron casting doesn't need a coating..glyptal is high dollar snake oil you ask me
Jack Shaft is offline   Reply With Quote
Old 04-23-2021, 09:49 PM   #7
CWPASADENA
CWPASADENA's Avatar
Glyptal definitely has it's place. It was very common to paint the inside of new castings to trap any sand or other debris that did not get completely cleaned from to pores of the metal.
The problem some folks have with Glyptal coming off is that the casting they are applying it to is old and has a lot of oil imbedded in the surfaces and it was not absolutely clean. Glyptal will not adhear to the surface if it is not clean and free of old grease and oil residue.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 04-24-2021, 07:29 AM   #8
Big hammer
In your case I would suggest adding an oil pressure gauge, making sure you don't lose oil pressure (1-2 pounds hot).
get a bigger hammer tap done
Old 04-24-2021, 09:53 AM   #9
Oldbluoval
Oldbluoval's Avatar
How much oil could the surface retain? 1-2 oz??
I’d never do it but I’ve seen it mostly 60’s drag racers
Oldbluoval is offline   Reply With Quote
Old 04-24-2021, 10:09 AM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by HD Rider View Post
What he said.
FYI, 'they' didn't quit doing this. It is still done by some of the top race engine builders in the country. Many other high-performance rebuilders do this also. Unless my customer tells me not to, I paint all the engines we do with Glyptol also. I stand behind my applications.
As Chris stated above, the coating is totally reliant on the cleaning process. Jet washing does not provide a clean base for a coating. Since many Model-A engine rebuilders do not have enough budget to do a thorough cleaning of the castings, then under those circumstances they should not use any coatings. For those that use a multistep process including thermal and soaking prior to jet washing and shot-blasting, then coatings provide a few added benefits and longevity.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-25-2021, 07:25 PM   #11
gdmn852
gdmn852's Avatar
On some Hudson built cars they were red Glyptol from the factory I had a 49 with a six that was painted .
gdmn852 is offline   Reply With Quote
