04-26-2020, 10:12 AM | #1 |
parts sources
I am starting to disassembly of the 1952 Crestline. I removed the engine and found the clutch equalize bar assembly loose and needs to be rebuilt. Which vendors are go to for the many parts I am going to find needing replacement. Also is there a source for better drawings. This drawing is from a 52-54 shop manual. It calls out Ford p/n but some are so small i cant tell what it is such as washes. Are they wavy, thick? Can part numbers be looked up somewhere? This is the start of the journey and need some guidance of the right direction for parts. Many parts are not listed by Ford p/n.Thanks in advance.
04-26-2020, 10:24 AM | #2 |
Re: parts sources
I use Concours Auto Parts in Carson City Nevada: https://concoursparts.com/
and C&G in Escondido, CA: https://cgfordparts.com/ For manual info try Faxon Auto Literature in Riverside, CA: http://www.faxonautoliterature.com/
Making the simple complicated for over 30 years. |
04-26-2020, 10:58 AM | #3 |
Re: parts sources
The part numbers you show in the Service Manual are just the basic part number,
you need a parts book to get the prefix that will identify the specific part for your car. https://www.ebay.com/itm/1949-1950-1...Vb1Ghx&vxp=mtr |
04-26-2020, 11:14 AM | #4 |
Re: parts sources
Try Third generation automotive in Va. G.M.
www.fordcollector.com |
04-26-2020, 11:41 AM | #5 |
Re: parts sources
35fordtn here on the Barn. His website isn't up and running yet.
http://thirdgenauto.com/ 615-293-9985.
04-26-2020, 02:17 PM | #6 |
Re: parts sources
I tried to link it, but it went to Corvette parts. All the websites, if you have time; Mac Van Pelt's is almost information overload. C and G has a pretty good site. Lots of info, if you got time. |
