08-30-2016, 04:33 PM | #1 |
'36 Ford rearend - # of splines?
I want to use one of the Speedway kits to adapt the stock rearend in my 36 to an open driveshaft. They have one for a 6 spline and one for a 10 spline...which would the 36 use? Thanks!
08-30-2016, 05:10 PM | #2 |
Re: '36 Ford rearend - # of splines?
should be 10 spline
08-30-2016, 06:11 PM | #3 |
08-30-2016, 10:01 PM | #4 |
08-30-2016, 10:02 PM | #5 |
B-4209-A
Ring & Pinion Set - 3.78:1 ratio PIC 1932 early style car & pickup $ 395.00 B-4209-HS Ring & Pinion Set - 3.54:1 ratio PIC 1932 early style car & pickup 395.00 40-4209-F Ring & Pinion Set - 3.25:1 ratio - Ten spline pinion PIC 1932 late to 1934 car & pickup 495.00 40-4209-HS Ring & Pinion Set - 3.54:1 ratio - Ten spline pinion PIC 1932 late to 1934 car & pickup 495.00 68-4209-F Ring & Pinion Set - 3.25:1 ratio - Six spline pinion PIC 1935-48 car & 35-47 pickup 349.00 68-4209-HS Ring & Pinion Set - 3.55:1 ratio - Six spline pinion PIC 1935-48 car & 35-47 pickup 349.00 8C-4209-HS Ring & Pinion Set - 3.55:1 ratio PIC 1948-50 F1 pickup 349.00 |
08-30-2016, 10:56 PM | #6 | |
Now on your last post you posted a lot of information, apparently copied from Mac Van Pelts website. This information looks to me to be for reproduction gear sets, probably made in Italy, that he is selling as new replacement gear sets. These gear sets available for '35 -'48 vehicles with original banjo style rears, are reproduced with 6 spline gears. No one to my knowledge is making '35-'48 reproduction banjo style rear gears with 10 spline pinions. If these repro gears are what you plan to use, then your only choice would be to use a set of these gears with a 6 spline pinion and buy the kit for an open drive that would be necessary for a 6 spline pinion. If you are planning to use a stock used set of gears, either what's in your car now, or maybe purchase another used set of gears in the preferred ratio, then depending on what that pinion spline count is, will dictate which spline count kit you will need to buy from Speedway. Hopefully, this is clearer than mud .
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 08-31-2016 at 08:44 PM. |
08-30-2016, 11:31 PM | #7 | |
08-30-2016, 11:51 PM | #8 |
I would recommend you buy the open drive kit from "Hot Rod Works" in Idaho.
Excellent quality & fit JMO Jim |
08-31-2016, 07:35 AM | #9 |
I second Kanuna on Hot Rod Works, they sell quality parts. Give them a call. And on the spline count, if I was doing this job I would remove the torque tube and count them. You can get your kit within a very short time and that way you know what you actually have!
08-31-2016, 12:44 PM | #10 |
I third that on hot rod works excellent quality,and good people, cubflyer
