Old 12-19-2020, 02:22 PM   #1
elwood
elwood's Avatar
Default 34 door help
Hey guys, Im repairing a set of doors, one of them the inner and outter skins are bad for around 2 to 3 inches up,
so i cut the skins off, as lest as possible, did the corner repairs, when test fitting the outter skin patch, and i can already tell that the outter skin on the door is wanting to curl inwards at the cut off.
how the heck do i get the original door metal to raise back up to meat the patch panel without having a dip at the seam ?
elwood is offline   Reply With Quote
Old 12-19-2020, 03:34 PM   #2
David J
David J's Avatar
Default Re: 34 door help
You overlapping or butt welding ?
If overlapping small sheet metal screws along the edge as needed to keep it tight . Remove them as you go and weld the hole shut .
If butt welding small machine screws-nuts and small washers as needed and again remove as you go and weld hole shut .
This way you actually drill through the seam so half a hole on each panel .
Simpler than it sounds .
Also if butt welding a flat piece of copper behind really makes the weld easier .
David J is offline   Reply With Quote
Old 12-19-2020, 03:44 PM   #3
Zeke3
Zeke3's Avatar
Check out this Youtube video from Fitzee's Fabrications, he has some great looking tips on how to avoid the concern you have. I am a big fan of Fitzee's videos.
https://www.youtube.com/watch?v=9MPykdZF9YU
Zeke3 is offline   Reply With Quote
Old 12-23-2020, 07:29 AM   #4
eddie48
Please explain more about using copper.
eddie48 is offline   Reply With Quote
Old 12-23-2020, 11:01 AM   #5
Zeke3
Zeke3's Avatar
The weld won't stick to the copper, so the copper can be used to backup the seam of the two pieces being joined. I also use a flattened piece of copper tubing to backup holes when filling them or starting a weld at an edge.
Old 12-23-2020, 11:57 AM   #6
johnboy34
Look up panel clamps, clecos, or just a couple strong magnets.
johnboy34 is offline   Reply With Quote
Old 12-24-2020, 07:23 AM   #7
eddie48
Interesting... I'll have to try that, next time. Thanks.
Old 12-24-2020, 07:25 AM   #8
eddie48
I just finished the doors on my 34 pickup. I replaced the skin from just below the ribs down. The ribs held the shape well so I could butt weld the new piece in. No warp at all.
